I bought a Ryobi rg950 generator and used it once. I wanted to use it 6 months later and it wouldn't start. The guarantee is now void. I stay in South Africa. Any suggestions?I bought a Ryobi rg950 generator and used it once. I wanted to use it 6 months later and it wouldn't start. The guarantee is now void. I stay in South Africa. Any suggestions?
You can't post conmments that contain an email address.
The picture scrambles because the video chip overheats and malfunctions. Open the case and do a full cleaning. If necessary add an extra fan - $10 at all IT shops.
It shouldn't make any difference which monitor you are connecting to any computer. In fact, I am running a 19" HP Flat Panel on my Dell Dimension 2400 right now. It is NOT a wide screen monitor as the Dell built in graphics card will not support the RESOLUTION RATIO required for the wide screen. Check what setting is "native resolution" for your monitor and see if your graphics card will support it. If not, using your old monitor, try different resolution settings. Right click on your desk top, click on properties and that should bring up the display properties box. Try a lower setting as larger settings are the ones that will give you a black screen. It will probably give you a smaller picture on your old monitor, or perhaps smaller or larger icons on the desk top. Accept the new settings, turn off your computer and switch monitors, and turn your computer back on. If you get a picture, but it does not fill the whole screen or the icons seem too large or small, then go back into properties from the desktop and try a different resolution ratio until the picture seems correct.
nVidia GeForce 7300 GT (256mb) Video Card
You can get one for dirt cheap on Newegg.com
Or your local PC store/Repair shop.
The Problem you are having is your Video Card Driver isn't the correct one, or it's got issues...
You should get a better video card.....yours might be onboard or really low-end rated.
FYI -
Pre-Manufactured PCs generally ****..... I build WAY better PCs for less.
HPs ****, but not as bad as a Dell (Dell does make the best pre mf 'd Servers which is ironic!)
but the worst pre mf'd PC I've ever fixed was a GATEWAY........
REPLACE 2SC5707 IN POWER INVERTER BOARD.
This parts is used to fix Some dell and hp lcd monitor.
DELL E172FPb, E173FPb. HP Pavilion F1703, Pavilion F1503.
If you can't get this item to work let me know, I can help
I have fixed a lot of these monitor with no problem.
