I want to connect an external mic to the camera
SOURCE: How do I copy from JVC GZ-MG365BU Camcorder to a VHS Tape? How do
ditch the VHS recorder. Burn them onto DVD. It's the 21st century.
SOURCE: JVC Everio GZ HD-40's external microphone problem
I have the GZ-HD40 and have tested the scenario below.
The problem is that the Microphones you are using are Mono, not Stereo. If you look at the plug on the end of your microphone you will see it has only two connections, the screen and the tip. For a Stereo mic it needs three connections screen, sleeve and tip, much like your headphone jack.
I know this is going to sound a bit nuts but use a set of head phones as a microphone. You will notice the left speaker acts as the left mic and the right speaker as the right mic.
Use microphone JVC MZ-V8 Stereo microphone and you will see that it has the three connectors as I have stated above.
Hope this helps.
SOURCE: how to get pics from my gz-mg365bu
Plug the USB cable into the computer and the camera. Your computer should recognize the camera as a mass storage device, and open a window allowing you to transfer the contents of the camera onto your computer.
SOURCE: Can I connect an external mic to a JVC Everio
YES - t built in microphone and the appropriate ports to allow connection of an external microphone.
GO to some eletronics store. Tell them you need a MIC with a MINI-JACK connector. mini jack is the end of the microphone - its really just the size - so.
Hope this Helped
x404x
