Question about Adidas Beckenbauer Shoes
Adidas Beckenbauer Shoes make an squeaky noise
The cheape tounge rubbing against the shoe itself make a terrible squaky noise that's just too loud and annoying, I can't use them because of this, how can i fix this?
Posted by beckenn on
Jim Pattison
    Master:
  • 1,004 Answers
WD 40 on the edge of the tongue shoud take care of this
Posted on May 10, 2014
My LG washer makes a horrendous noise when it in use. what could cause this?
Open door and see if you can move inner tub without the outer rub moving. If you can the 'spyder' which hold inner drum to axel hub is broken. Post results in comment section
May 21, 2018 | LG Washing Machines
Samsung washer tub is shredding. Top load model WA400PJHDWR/AA. Was making terrible noise when spinning and when I opened it, bits of plastic were everywhere. Looks like top of tub is rubbing against...
best thing to do is call the store where it came from and let them replace it with one just like it or exchange it with one around the same price
Oct 02, 2013 | Samsung Washing Machines
Are there special squash shoes?
Apparently there are special shoes for squash. you can simply google squash shoes, and you will land on many options like this one: http://www.tennisnuts.com/shop/squash/squash-shoes/adidas-badminton-squash-indoor-shoes/adidas-squash-shoes.html
Jan 17, 2013 | Sport & Outdoor - Others
Freezer is making a loud noise. sounds like the motor. GSS201EMA
inside the compressor there are springs which prevent the motor from banging against the case. If one of them breaks the compressor will make quite a bit of noise, It doesn't affect function but is very annoying.
Aug 07, 2011 | GE GSS25SGRSS Side by Side Refrigerator
I have a HPDV9000 Laptop and it is making a terrible loud noice, very annoying. Starts when turned on. What can it be. Thank you.
More than likely it's one of the cooling fans. They spin at relatively high RPM and if they're damaged they can emit a loud whirring or screeching noise. If it's a clicking noise then it could be your hard drive failing.
May 04, 2011 | Computers & Internet
How do you clean the Ecco Glide shoes?
Ecco Glides are good shoes, made of leather, not cheap plastic imitation leather. In the household aisle of the grocery store or a big-box (Wal-Mart or Target) store, find a tin of saddle soap. It's specifically designed for cleaning leather.
Follow the directions on the soap, but mostly it boils down to three steps:
1. Use a moist/damp rag and get most of the dirt off.
2. Use a (clean!) damp rag to rub a small amount of saddle soap all over your shoes. Rub it in well.
3. Use a (non-soapy!) damp rag to remove the soap.
Apr 30, 2011 | Ecco Glide Shoes
My white SL 72 SHOES got covered in indigo dye from my jeans. i want them to look white again what should i do?
just rub the stain wid cleaning solution or soap aolution and apply some polishing agent over it
Mar 11, 2011 | Adidas Sl 72 Shoes
Adidas Beckenbauer Shoes Logo
822 people viewed this question
Top Adidas Clothing Accessories Experts
Marvin
Marvin
john h
STEVE SPAM REMOVER
Are you an Adidas Clothing Accessory Expert? Answer questions, earn points and help others
