MSI TVAnywhere Plus (TVANYWHEREPLUS) Video Capture Logo
Anonymous Posted on Aug 24, 2012
Tv@anywhere plus remote wont work in win7 32-bit windows media center
Xbox set up
If you have an Xbox 360 connected to a home network that also has a Windows Media Center, you can add your Xbox 360 as a Media Center Extender device so that you can enjoy the digital media on your Windows Media Center computer by using Xbox 360. For more information, see Xbox 360 online.
1. Turn on your Windows Media Center computer and log on to Windows. Verify that your computer is connected to your home network.
2. Turn on your Xbox 360 and verify that it is connected to your home network.
3. In Windows Media Center, on the start screen, scroll to Tasks, and then click add extender.
4. On the Welcome to Windows Media Center Extender Setup screen in Windows Media Center, click Next.
5. Press the Green Start button blank.gif on your Xbox 360 remote control or use your Xbox 360 controller to select the media blade.
6. On your Xbox 360, select Media Center.
7. On your Xbox 360, follow the instructions on the screen to obtain an 8-digit Windows Media Center Setup Key. Write down this 8-digit setup key. This is the key that you will use to affiliate your Xbox 360 with your computer that has Windows Media Center.
You do not need to download any additional software because the Extender functionality is built into Windows Media Center.
8. On the Enter the Setup Key screen in Windows Media Center, use the Windows Media Center remote control or keyboard to enter the 8-digit setup key that displays on Xbox 360, and then click Next.
9. Follow the steps in Extender Setup.
Several changes are automatically made to your Windows Media Center computer during the Extender Setup, including changes to the Windows Firewall settings. For more information about Windows Firewall, see Windows Firewall: recommended links. During this time, the Windows Media Center Extender service (which is named mcx2svc) starts on your computer, along with other dependent services.
If you have a firewall running on your computer that is not the Windows Firewall, make sure that the firewall software is set up to allow Xbox 360 to connect to your Windows Media Center computer as a Windows Media Center Extender. Some firewalls are already set up to allow Xbox 360 to connect to a Windows Media Center computer as a Media Center Extender. However, other firewalls will require you to make changes to how the firewall software is set up. For more information about which firewalls are already set up to allow a Media Center Extender connection, as well as information about how to set up other firewalls to work with a Windows Media Center Extender such as Xbox 360, go to the Firewalls and Media Center Extender article on the Microsoft website.
10. After Extender Setup has finished, in Windows Media Center, click Finish.
On the TV that is connected to Xbox 360, the Windows Media Center user interface appears. You can then enjoy live TV, recorded TV, pictures, music, videos, and other digital media on your Xbox 360 as you would in Windows Media Center. A new user account named mcx1 (by default) is automatically created to use the Extender.
Please see http://windowshelp.microsoft.com/Windows/en-US/Help/8076aff3-16ec-4751-9f57-d36e0ff407201033.mspx#EPD for more info.
Thanks and hope that helps!
Les
Windows Media Center can't detect a TV signal from a Sabrent card
If you have hd card, it might be your cable company not providing hd signal. If you have analog card, and have HD signal that will cause it too.
Media Center for Window XP, TV don't work.
Try reinstall windows. If this doesn't work you might have a conflict with your tv-tuner
1helpful
My laptop responds to tv remote
you can turn off the IR on the laptop or put black tape over it!
1helpful
Sky + Remote wont change volume or mute after buying a new tv.
I have since found the code. 206 worked straight away which I hear is good as some people have to try numerous codes before it works. You press tv, press select and red button simultaneously for a couple of secs until the red remote light blinks, then press 206 and finally, select to save. This worked for me so hope it helps anyone else.
Windows XP Media Center Remote control wont work anymore
I have solved the problem. All i did was open windows media player and use the remote control to operate it. From then on it worked fine with windows media center. Hope it solves your problem too. good luck.
1helpful
Access violation in main center exe.
Try un-installing then re-installing the software for the usb stick.
Top MSI Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a MSI Televison and Video Expert? Answer questions, earn points and help others
