The oven and speed bake fun intermittently work. At beginning the oven heats up but then speed bake fun stop working that affects oven and it stops working too. Control panel shows everything is all right but neither fun nor oven works. Need to cancel baking couple times in order for oven to begin to work again.
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
SOURCE: Upper Oven doesn't heat in bake or broil. Lower /Ctrl panel OK
check to see if both ovens are the same circuit if they are you have a internal problem with your upper oven internal circuits or damaged wirering contact a qualified service tecnitian
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
SOURCE: Oven stops working and display screen goes blank
Hello The control has developed faults in one or more of it's circuits. This clock/timer must be replaced to solve the problem. The Good news is that this is not one of the really expensive controls. Found this one for about 70$ at a website. Worth fixing- but beware the 'self-clean' function after repair, and this control should last a lot longer. Please acknowledge this post if info helps- have more if needed- Thanks- Ed
Testimonial: "Thanks for the great information. This WAS VERY HELPFUL."
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
If
problem.
Oven
heatman101
