My lap top keeps shutting down in the middle of what im working on. i have order a new battery for it thinking that was the problem . But even when i have it pluged in it shuts off on me. how do i reset it back to factory settings
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
SOURCE: acer reinstall issue
Run the same procedure again and choose factory settings. It wd do so , unless the recovery partition got corrupted.
SOURCE: im trying to reset my acer to factory settings and
u can go on u tube there is an instruction video i did it on my acer and firt time did not work and second time it did go to u tube put how to reset factory settings on my acer and what model it is
