Kenwood KDC-716S CD Player Logo
C Watford Posted on Aug 23, 2012
How do I get the display screen to illuminate?
The lcd screen on my jl 250 dosent light up i switch on
If the LCD screen on your JL Audio JX250/1 amplifier is not lighting up when you turn it on, there may be a few possible causes:
• Faulty power connection: Check that the amplifier is receiving power by verifying that the power light is illuminated. If the power light is not on, there may be a problem with the power connection, fuse or wiring.
• Blown backlight: If the power light is on but the LCD screen is not illuminated, the backlight may be blown. In this case, the LCD screen may still display information, but it will not be visible without a backlight.
• Faulty LCD screen: If neither the power light nor the LCD screen are illuminated, there may be a problem with the LCD screen itself. This could be due to a faulty display panel, cable or connector.
2helpful
2answers
I have a hp2000 with a black display screen
your problem is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google
3helpful
2answers
My Dual XDM7510 display quit working and I can't find out what is wrong. Everything else on the XDM7510 works. Help me please. It was working when I went in the store came back out and no display.
try checking the illumination light on the back of the radio if that doesnt work then try looking at the red ignitionswitch wire and make sure it is connected to the 12vt constant (the yellow wire)
2helpful
2answers
Sony Erricson z550i Phone display not switching on!!!
in most cases the fibre ribbon gets worn out.
you can try a local cellphone repair shop, or sony service if you can afford it.
the ribbon needs to be replaced.
Display illumination
go to the manufacturers website for your laptop and look for the Support Tab or menu.. click on it and look for Driver Downloads or similar.. then Download all Vista compatable drivers available..
Lcd screen
Cannot get images deleted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
