I replaced the a/c compressor two weeks ago because of this noise and that the pully bearing was shot. Now it is starting to make this noise again. Clearly there is another issue. The air blows cold out of it and the system is not leaking. I did notice when I checked the pressure before I changed it that the pressure went off the gauge. Could this be an expansion valve? I am not fluent in a/c repair
SOURCE: LAST WEEK I HEARD A
Check the tension on your compressor belt, sounds like it might be slipping during acceleration.
SOURCE: 2003 Air Conditioner not blowing cold air
If it goes down again,take it back to the mechanic.He will shine the system with a uv light to enhance the dye and find the leak..Good Luck!!!
SOURCE: 2001 cavalier air conditioner blowing hot air
Why do they want to replace the compressor?noisy?If you can put a charge on the ac then it's hot again after a day,then you have a leak.all the ac lines have o-rings where they are connected.without put dye in the system you wont know for sure.So I would try that first.
Take it to a garage and have them evacuate the system and refill with refrigerant. you have air and non condensibles in the refrigerant system.
