Need to replace circuit board on AVC unit.
SOURCE: No AVC media box
You should be able to use this with only the DVI connection as just a large monitor. You can use a DVI to HDMI adapter as I do believe the display is HDCP compliant. Many AV receivers will upscale to the necessary 1920x1080p resolution that the display needs.
SOURCE: i have a sharp lc 30hv6u that needs the avc system
There is no way around AVC, You will need it. unfortunately, it's expensive and hard to find.
SOURCE: Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
SOURCE: My aquos LC-30HV4U no longer
This would be a circuit board issue indeed, its called the controller board and that has you buttons and your ir sensor on the front to boot. If that gets replaced you will have a fine working unit again.
questions? please ask
otherwise please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
