Acer Aspire One Netbook Freezes Constantly Playing Video
This netbook freezes playing any video any source except Vimeo. It freezes playing minimized as well as full screen, playing Video imbedded in websites, such as news sites; freezes after 1, maybe 2 YouTube videos, everything stps working: cursor, everything. Has not yet frozen playing a video on Vimeo. Also freezes when 2 or 3 windows open sometimes, and when open a website that is heavy in graphic; freezes if anti-virus or adobe or anything else tries to auto-update while using system; also Microsoft Auto-updater will no longer run- will not check for updates gives 800B100 Error cannot fix error- have to look up updates each month and manually update and install.
Posted by Ben Sharp on
kieren
Ive got a kav60 netbook and the video and audio freezes, makes a nasty buzzing sound. i also have a problem with my mouse, it goes crazy, or sometimes doesnt respond unless i apply pressure to one side of the netbook (slightly bending). tried disconnecting the touchpad, and applying an external usb mouse, but it sometimes freezes the cursor,or the cursor does its own thing. please help
Posted on May 30, 2013
5 Related Answers
Anonymous
  • 44 Answers
SOURCE: My Acer Aspire One 150 netbook freezes even after OS re-install
Try formating your harddrive and reloading the OS. If that doesn't work you might need a new harddrive.
Posted on Feb 08, 2010
Anonymous
SOURCE: Streaming Video Freezes sound continues
You have the wrong screen resolution. Lower your resolution and it will work fine.
Posted on May 11, 2009
Anonymous
  • 859 Answers
SOURCE: acer aspire video hardware error
I just wanted to take a moment and acknowledge your request. It sounds to me, on first instinct, that your video encoder/decoder software components may be or probably is faulty and or just not up to date. A hardware video display adapter such as your Nvidia Geforce Go also has a video encoder/decoder chip. Either one or these two, both dependent on the other, may be at fault. I'll send you a link later with a package to download and install that will update your encoder/decoder set. This set of software instructions installs as a package and is not usually available from MS update or from Nvidia as an update. Why this continues to be so baffles all we techs. Fortunately the package is free and published by members of the free software open source movement.
Just realized that this *still*, may be a hardware fault where your laptop is trying ot go into screen saver or monitor blank as a power saver and is failing at the point where it should realize you have an open tunnel on the IP band that Skype and IM programs use. By failing to recognize you are using display resources while Windows is otherwise not busy, that when Windows wants to initiate a Screen Saver mode or blank the display driver this *failure*on Windows part to Check for Open Applications is also likely to be at fault. This error is hardware related and thus causes the system *hang up*. If it were at the software level, you'd just loose your tunnel session in IM or on Skype and you'd have to restart the app.
It is not easy to express this issue as I see it in general terms. So, I apologize it you are confused. I'll find the encoder/decoder package and post that to you a bit later after I get some more data from you. Would you tell me if you have Vista or XP and what SP version you have? Press these two keys at the same time to have this info displayed, "Windows Key" + "Pause" key. You'll also see info on your notebook builder and how much RAM you have onboard.
Do you also have an independent Memory Manager running? And, what are your Screen Saver setting, and what screen saver runs, then what is your Power Scheme setup? Do you have monitor off set for something similar to the duration of your screen blanking? Often there are setting for this not only in the Windows Control Panel Display module but also, when you startup your laptop you can press Del, F2 or F10 what ever hint you see in the upper area of the screen during bootup for a key press to enter System Settings. In side the system settings is a page where you can set display time outs for battery savings. Check those and see what those numbers are and send those to me also.
Then, if this weren't enough, Acer has this EPower module, usually displayed as a green bar or stripe in your system tray where the digital clock is located. EPower steps down the processor (CPU) clocks depending on your task. It can actually step down your processor speed to as much as 700MHz. This EPower module is rather infamous for causing problems for apps that need full processor speed... much like what you are wanting to do.
Use the comment text area entry box below to comment back to me. Ask me any questions you need to gain clarification on what I've just discussed before we move forward from this point.
Please realize, there is a good chance I can assist you in solving this problem. There is a good chance I may ask another Expert and friend of mine to confer on your problem and lastly, this may actually be narrowed down to a hardware fault, but if so, I will assist you in what to state to Acer and what data to include in a call for warranty service.
Regards,
Worldvet
Posted on Nov 08, 2008
Anonymous
  • 92 Answers
Most streaming video run through flash media and you must set the feed setting in micromedia flash players to your download speed or it will be intermitiate it is security because virus and trace bugs can be encoded into flash media and tag your info evento the point of remote logging soo all you have to do is go to control panel and go to internet setting and allow the download in your sucurity setting that it .try it let me know what happens.
Posted on Apr 02, 2009
Colin
  • 1584 Answers
SOURCE: Acer Aspire 5335 Crystal Eye Cam Not Working
Hi
Go to this URL and click on drivers and utilities / select correct driver type.
http://support.acer-euro.com/drivers/notebook/as_5335.html
NB = Always use manufacturers site for these downloads.
Cheers cbacer
Posted on Aug 12, 2009
Netbooks atom 1gb intel
Sometimes I remove the battery when it freezes, then replace it and restart in safe mode, repair mode or whatever. If you get jiggy with it eventually it restarts. One develops skill at mitigating a freeze.
Feb 04, 2014 | Acer Aspire One D257 Netbook
When I play a streaming video on my Asus 1000 HE I get horizantal lines running through the video and it sometimes freezes.
That is most likely just a problem with the streaming video. If other sources do not work, try to uninstall, and then re-install Adobe Flash Player. That will most likely help.
Aug 01, 2011 | ASUS Eee PC 1000HE Netbook
My mousepad it is locked on an Acer Aspire D255-2DQkk after a game that I was playing has locked and I needed to reboot the Netbook
The game has some software which made the computer to lock its mousepad up. There's a way to unlock it after playing the game. Just press FN and F7 keys altogether. It should work.
May 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire one netbook lags and sometimes freezes when I play audio PLEASE HELP
As with any computer, after a while it's going to start to slow down because of programs and files being added and your computer will become memory hungry. Do you have alot of programs installed on to it or files installed on to your netbook? and are you multitasking when you are playing audio like using windows media to play it? If so, your netbook can't handle all the treads from the program because it's underpowered. The Acer netbook is underpowered to do multitasking. It is only meant for internet browsing and typing. It is not meant to be handle like a laptop. If I am correct your version comes with 1gb of ram only and you may need to upgrade your memory to 2gb which is the max allowance to help ease the lagging. However you can also try defragmenting your drive too, but as recommendation, you will have to upgrade you memory.
Jan 31, 2011 | Acer Aspire One PC Notebook
My netbook freezes everytime I try to turn it on.
Try starting in safe mode...Then check your event logs...Could be a driver hanging or a virus.If it's a driver ...delete it...then install it again.
Mar 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
Feb 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
My acer d250 netbook freezes when i listen to music or watch movies
Try it in safe mode and see if it does it there. My netbook did the same thing and would randomly BSOD and it turned out to be the Hard drive. Good luck.
Nov 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
k24674
