Already Tried: i have used MiniTool POwer data recovery software to recover all the files. currently running testdisk software to fix it but it's still analysing the whole hard drive. Browser? Chrome 20+ (v.21) OS? Windows 2008 Flash? Yes Resolution? 1920x1080 Cookies? Yes please take into urgent notice!!
I'd recommend that you try asoftech data recovery which is one of the best file recovery program
http://www.asoftech.com/adr/
It
happens at times that we knowingly delete some files permanently and
later realize that they were important. It is possible to recover
such files easily by using third party software of Windows disk
recovery. They are capable of recovering files that were deleted long
back and even the files deleted due to formatting, damage or deletion
of the partition.To know more about the tool visit http://www.downloaddatarecovery.net/
Have saved all your desired drive files back? It's great! In fact, I had ever also successfully rescued most of desired photos, Word files, videos and some songs off from my mistakenly formatted USB flash drive. But, I just use different drive format recovery software that has offered me four well-designed data recovery modes.
So, if anyone there also has been stuck in similar drive data loss issues, he can also take chances with that software here:
http://www.ucfix.com/data-recovery/data-recovery-after-format-external-drive-hdd.html
Always save several copies of your important drive data on different devices or locations well.
I am really happy to hear that you've restored all your left drive files back. You are really lucky! In fact, not too long ago, I also have similar drive information loss problems for RAW file system error and all inner stuffs cannot be accessed without formatting process.
So, in order not to format this drive and erase everything inside, I had tried many data recovery software recommended in different forums and articles. Luckily, I had also rescued most of my stuffs back.
Here are more data recovery articles that may also help anyone there:
Detailed steps to restore external hard drive data
Restore lost data from formatted USB hard disk
Based on your description, your computer
system seems to have some problems. Therefore, why not to try this external
hard drive on anther PC?
If it could work well there, you'd better
fix the system problems of your computer and back up all your important data on
this external hard drive.
But, if this drive gets the same problem
unfortunately, you also could go on using drive data recovery software to take
chances.
I know you've tried many data recovery
programs. But, have you tried this drive data recovery freeware?
http://www.icare-recovery.com/data-recovery-free.html
I have tried it before. It really worked
perfectly and restored all my wanted files back from my WD hard drive. I still
remember it has offered four data recovery options for me, such as "Format
Recovery", "Advanced Files Recovery", "Partition Recovery" and "Deep Scan
Recovery".
I truest it will work well on your drive.
Just give it a shot!
You can recover all files and folders from Windows 8 by using Remo Recover Windows Free utility, it has ability to recover files from any type of situation.
SOURCE: My LaCie was working great and suddenly I can't
First DO NOT FORMAT IT!
Try plugging it into a different USB port. If its a 2.5" drive use the power cable adapter that came with it. Check to see if it works on another computer.
SOURCE: My PC does not see my external hard drive any
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
SOURCE: wd 160d passport external hard
CardData Recovery can recover data from all camera flash memory cards includingCompact Flash Card (CF), Smart Media Card, Secure Digital Card (SD),Multi-Media Card (MMC), XD Picture Card (XD), Micro Drive, Sony Memory Stick(Duo, Pro), as well as removable storage including Zip disk, USB drives andHard drives. Recovery of files is also possible even when drive has beenformatted.
http://www.card-data-recovery.com
