Cnet CWR-905 Wireless-N Router Logo
Question about Cnet CWR-905 Wireless-N Router
How to factory default router cwr-905
I want to reset my router to factory default
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: CWR-854 router
Type in the address of your router - you say that is set to192.168.1.254 and you will see the config page( after logging in ) for your router. This is more usually 192.168.1.1 though .
Posted on Jan 25, 2008
Anonymous
  • 144 Answers
SOURCE: CNET CWR-854 Wireless G problem.
hello!
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
Posted on May 05, 2008
Anonymous
  • 46 Answers
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Posted on Aug 10, 2008
Anonymous
  • 137 Answers
SOURCE: Got a new router after lightning blow my old one,
Probably your internet providers modem has blown also.Without the router do you have internet connection?
Posted on Jul 10, 2009
Anonymous
  • 84 Answers
SOURCE: I can't reset my cwr-854 router by pressing the
You can reset this Wireless Access Point by clicking on Reset button, and then press OK button to confirm your decision.
Note: you can also hold down the reset button for more than 10 seconds to reset its default settings back to factory default.
If the reset doesnt work turn off router then on again first, but if the reset doesnt work, the router may need to be replaced.
Posted on Oct 20, 2009
Howto gain access to CNET CWR-905 Wireless-N Router
This webpage has some information on the router, sorry I could not be more help but I am not familiar with this router.
Webpage
1helpful
After factory reset, my computer dont recognise my router
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. Toconnect to your wireless router from the computer/laptop, configure thewireless card in your computer/laptop with the router's wireless settings ieSSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
I need for a new username and password
You should perform a Hard Reset to restore the router to its factory settings. This will automatically reset the password to the default listed in the manual. From there, you can easily change the password (and the user name) in the router settings to whatever you see fit. 1. With the router plugged in, used a pen or similar object to depress the router's recessed reset button. Hold it for 30 seconds, then, while continuing to hold the button down, unplug the router. 2. Hold for 30 more seconds with the router unplugged. 3. While continuing to depress the button, plug the router back in and continue depressing the button for a final 30 seconds. Your router should now be restored to factory settings.
How to secure wireless network?
go to ip address of the router then make it secured.
After changing the ESSID and wireless password of CNET CWR-905, connection was lost. What could be wrong
Contact you provider to see if you can get the router configuration set to "Default so that you can gain connectivity again.
Changes in the router ESSId cause the router to change all parameters therefore locking the connection.
You can reinstall the router software and start from scratch to reset the router and enter a new ESSID password but I would get with the ISP and go through there setup procedure to ensure proper settings for their server. You probably missed something when replacing the password.
3answers
I can't reset my cwr-854 router by pressing the RESET button for more than 1 minute and nthing happens , either in Power ON and OFF
Unable to access web management interface of wireless router
First press RESET button it is in back side of router press it for 10 seconds so all settings are defaults.
Then connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Let me know if you need more assistanse.
Thanks.
Let me know
comier957
Cnet CWR-854 does not work
You may be advised to use an RJ45 LAN cable to try the following, then use the wireless connection when all ais up and running. The default Login ID and Password is ?root? with password ?1234?. This Wireless Access Point?s default IP address is 192.168.1.253, You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision. Note: you can also hold down the reset button on this Wireless Access Point?s panel for more than 10 seconds to reset its default settings back to factory default. If the reset doesnt work turn off router then on again first, but if the reset doesnt work, the router may need to be replaced.
Top Cnet Computers & Internet Experts
 Mike M
Mike M
NOEL
NOEL
matt
matt
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
