Are you usingoriginal HP Dimm chip?, does machine turn on and come to ready when it is standing on it own (not hooked to p.c.) if not can you tell me exact light patten displayed
go to the control panel, select printers and double check if the Ricoh Aficio CL3000 Laser Printer was selected as a default printer. you can check it by right clicking the printer name and choose set as default.
Remove the ribbon along with its fitting from the printer and fix it back. Replace the ribbon, if in case worn out or used excessively or stuck within. I hope this fixes your problem.
mcdevito75 here, Chances are the message means to give the printer the instruction to scan from the computer iteself and not at the printer. You may have to un-install / re-install your printer program if you have the printer cd. Also you can go to start, then control panel then printer and check settings there.
is there an error code appear on panel display? if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
