My Chrysler Sebring Conv. JX is acting up. When I drive it, or drove it. The left side would click like the blinker was on. The defrost button for the rear window would click and flash, and the headlights flashed. The radio doesn't work since this started and when I speed up it sounds like the car might quit on me. Now whenever I start it i have to hit the gas a few times before until it starts. I want to sell it because i'm buying a new car but I'd like to know whats wrong with it so I can either fix it or tell whoever buys it what needs to be fixed. Any ideas?
The first thing you do is have the battery and the battery cables checked, it sounds like a dead battery to me. The battery is accessed through the drivers side front wheel well through an access panel. Remove the front left wheel first.
SOURCE: how to fix code p1698
off the top of my head I am not sure w\hat exactly that code is although I do now it sound familiar. Most code tat are p one codes are usually more of an electrical problem or even a sensor. For that code all I can say right now is possibly a speed sensor issue or wiring
SOURCE: CLICKING NOISE WHEN TRYING TO
My daughters did the same thing 2001 Sebring--red cable under manifold lose try moving it toward you a little this cable goes to the starter and runs to the battery thats located in wheel well of all places
SOURCE: 2001 Chrysler Sebring Conv - lights on rear view mirror problem
also check to make sure your dimmer switch isn't turned all the way up. if the dimmer is all the way up your interior lights will stay on. check your dimmer switch
SOURCE: Saturn 2002 VUE Turn Signal not working properly.
You need to check your left side turn/park lamp bulbs for correct part # & installation.If that checks out you deffinetely have a ground problem.When you have other lights blinking with you turn signals you have either a bulb incorrect or a bad/poor ground.If bulbs check out check your forward lamp harness ground.Hope this helps
SOURCE: need the torque specs for
Fig. Intake manifold bolt torque sequence 2.7L engine
Upper intake manifold with a new gasket on the lower intake
manifold and torque the bolts, in sequence, to: 105 inch lbs. (12 Nm)
Hope helps (remember to rate this answer). Good job.
