Has worked fine for approx 5 years, but now suddenly does not power on when pushing the power button. Nothing else plugged into neighboring outlets has similar problem, and changing batteries in remote (even though I'm pushing power button on the component) didn't help.
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
I Have a denon 2113 which turns on displays for a few a seconds and goes of leaving the red light flashing what could be the problem?
SOURCE: Denon AVR-1707 Receiver - remote stopped working
please apply a new fresh battery to it-confirm from right orientation(polarity)-try to apply a contact cleaner spray over the bad button and press it many times.-remove any thing between remote and receiver.-you can use universal remote and confirm befor you buy the new remote that it support your receiver.
SOURCE: Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
solutiondoct
SOURCE: denon avr 885 it automaticallyshuts off when i try to power it up
Its possible that the Receiver is going into protection mode and possible some speaker cable might have touched the body or with each other.
Remove all inputs and outputs and then restart the receiver. If it starts then you are lucky. Connect all cable and wiring properly and ensure that they do not touch each other. You might have to reset the microprocessor also.
If the problem persist then let me know to further the trobleshooting.
Please do rate this solution and thanks for using FixYa.
SOURCE: Denon AVR-1908 speaker issue
Before we play taps and throw dirt on top of the Denon, perhaps a bit more triage is in order. I'm not certain who the patient is. Especially when you have "speaker issue" in the title. Are you saying there are some speakers that don't work ONLY with BluRay?
If it has NEVER worked the (unnamed) BD player or its cable(s) could be at fault, too.
What 'connections' are we talking about. HDMI, coaxial- or optical audio, 5.1 analog; to what input on the Denon assigned to what function?
Have you tried all audio paths out of the BD player? Is it configured to squawk in the right digital mode?
Do you have any other digital audio sources (CD/DVD) you could use to certify the audio paths that don't work with the BD player?
Thanks - the answer to all of your questions is no, so I guess it's a fuse. Is that something you could get online and replace yourself, or would you expect I should be able to find a repair shop to do somewhat inexpensively? Thanks
I have a Denon 2113 which turns on displays for a second switches off and the red light starts to flash. what coul be the problem? Kindly assist...
