12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Thanks for choosing FixYa,
Kelly
If you are talking about the transmission oil , 10w-40 JASO MA motorcycle oil will work. Most racers will use either an 80 wt (weight) motorcycle gear oil or for the racers edge a 70 wt motorcycle gear oil to increase the life of the aluminum plates in the clutch and help preserve the transmission gears.
You'll need the following. Painter's tape or Masking tape, 2000, 2500, 3000 grit
sandpaper, bucket of water, headlight polish (PlastX, etc) and microfiber cloths
Mask off around the light so you don't have to worry about sanding your paint if your hand slips.
Soak the sand papers for at least 15 minutes. The more water the better
Using the lowest grit, start sanding in ONE DIRECTION ONLY,(side to
side). Keep the sandpaper wet and dip it in your bucket of water
frequently. Now dry the headlight and it should look all hazy
Switch to the next finer grit, and repeat the step above, but this time
go in the OPPOSITE DIRECTION (up and down). Keep using water Dry it again, and it will look better than the first time.
Repeat the process again with your finest grit. Again, OPPOSITE
DIRECTION with plenty of water. Dry it off. It should look relatively new at this point. Remove the tape as it will contain bits of grit from the sandpaper.
Generously apply the headlight polish in a circular motion to the headlight
Using your microfiber cloth, rub off .. repeat several times with FRESH
rags until the polish is dry and gone.
