WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and
then open the top where you load the DVD into the player. Locate the
laser lens
and notice that the laser is attached to a transport assembly that
moves the laser
diagonally outward in a slot. 1. Slide this assembly outward to the end
of its track. 2. Slide the assembly back inward to the closest inward
position. 3. Repeat the process of sliding the assembly outward and then
back inward.4. Put in a music CD and let it play all the way through.
This helps to calibrate the laser head assembly movement. When the
music CD is finished playing. 5. Put in a DVD, and you should have a
working unit
again This is a factory solution from Mintek that was given to a
customer who ask for help with the forever loading disc problems. This
solution may work on other models of portable DVD players. Most
portable DVD players use this type of transport mechanism. Try this
solution it might work for you.
