Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Mike Jones Posted on Aug 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water does not stop running into the tube
When the washer is shut off the water still keeps on dripping into the tub and has to be drained every hours.
  • Official Brand Answer 4,342 Answers
  • Posted on Aug 24, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466567
Points
5907
Sounds like a professional needs to diagnose and repair/replace the water valves.
5 Related Answers
Anonymous
  • 2382 Answers
  • Posted on Nov 07, 2010
SOURCE: Hi, I have a Frigidaire
Hi, if your washer is overfilling/overflows the tub, check these:
  • Water-inlet valve
  • Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Anonymous
  • 5911 Answers
  • Posted on Oct 29, 2008
SOURCE: Washer keeps draining
Sounds like you may have a siphoning problem. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Double check your installation and drain hose placement. You need to ensure you have an air gap to break the suction caused by the drain line. In the event that this is not a simple siphoning issue, please let me know if you require additional assistance. I hope this helps you.
orzechoski
  • 77 Answers
  • Posted on Apr 26, 2009
SOURCE: Water leak from front load washer - Frigidare GLTF1240A
just remove bolts, open bit enough to fill with silicone, close back wait to dry, ready to go for couple more years.
Anonymous
  • 68 Answers
  • Posted on May 02, 2009
SOURCE: SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
Anonymous
  • 130 Answers
  • Posted on May 07, 2009
SOURCE: Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Dripping in tub when complete
If your Kenmore washer series 400 model 22102 is dripping water in the tub after the cycle is complete, there could be a few potential causes. Here are some things to check:
  1. Water valve: The dripping could be due to a faulty water inlet valve. This valve controls the flow of water into the machine and if it's not closing properly, water can continue to drip into the tub even when the cycle is complete. You may need to replace the water inlet valve to fix the issue.
  2. Water level sensor: Another potential cause of dripping could be a malfunctioning water level sensor. This sensor tells the washer when the tub is full and it's time to stop filling with water. If the sensor is faulty, it may not be accurately detecting the water level, which could lead to dripping. You may need to replace the water level sensor to fix the issue.
  3. Drain hose: If the washer is not properly draining, it could also lead to dripping after the cycle is complete. Check the drain hose for any kinks or clogs that could be preventing water from draining properly. You may need to clean out the drain hose or replace it if it's damaged.
  4. Overloading: If you're overloading the washer with too much laundry, it could be causing water to overflow and drip into the tub after the cycle is complete. Make sure you're following the manufacturer's guidelines for load size to avoid overloading the machine.
If you're unsure of how to diagnose or fix the issue, it may be best to consult a professional technician or reach out to the manufacturer for assistance.
2helpful
It stop at the point where water is filled tp the max (i think, covered all the items)
If its overfilling:-- If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
4helpful
2answers
Does not stop filling with water
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
2answers
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
2helpful
Water doesn't shut off
Hi There
I have looked up your problem that you are having. Read this and let me know how it goes. Hope this gets you in the right direction.
If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.\
Thank you for writing to fix ya.
Best Regards Richard
Have a hotpoint top loading that A..would not stop filling even unplugged, and B. will not drain/spin. Hence, ended up with a flooded room while I was trying to get the water turned off. Any easy way to...
Hi
Water-inlet valve
Water-level switch
When it doesnt spin or drain...
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting fixya.com
Washer over fills and water comes out the door. Water continues to run even durring the pump out cycle just before the spin cycle
  1. Water inlet valve. It may not be able to shut completely when the electricity to it has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow. Remove the washer's cabinet to access it.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
  3. Air-hose. It is connected to the water level switch through a tube. If the tube or hose is cracked or broken, no enough pressure builds up to trigger the switch and shut the water supply off. Check it for any obvious damage.
4helpful
Washing machine won't stop filling
Hello Marty, there are only two possible reasons for your trouble.
Water-inlet valve
Water-level switch
2helpful
Washer keeps filling up with hot water
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
1helpful
2answers
Water continues to run and over flow as cycle won't start
Hi!
There are two main reasons due to which the water is overflowing out of washing machine---
1. Water Inlet Valve: A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
2. Water-level switch : A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
