Question about Saitek Video Game Consoles & Games
Saitek av8r-02 controller settings for microsoft flight sim X
Controller settings for microsoft flight sim X
4 Related Answers
Anonymous
SOURCE: AV8R manual
Got to www.saitek.com and download the relevant manual
Posted on Mar 16, 2009
Anonymous
SOURCE: Use of AV8R-01 with Google Maps flight simulator
My blackwidow joystick would not work in google earth, the sim would just crash. I tried a surgestion to remove the blackwidow software and just run it with the ms hid driver. It now works fine, even the throtle and rudder controls.
Posted on Mar 30, 2009
Anonymous
SOURCE: saitek aviator joystick av8r-01
I had the same problem.
Unplugging the joystick and plugging it back again seemed to fix it for me.
Don't know whether it will work each time.
Posted on May 31, 2009
Anonymous
  • 13 Answers
SOURCE: Hi;How do restore the calibration screen for the
You can use Clear Calibration Utility, which will help you get rid of all the calibration data.
32bit version: http://www.wingmanteam.com/files/Tools/ClrCalib/x86/ClrCalib.exe
64bit version: http://www.wingmanteam.com/files/Tools/ClrCalib/x64/ClrCalib64.exe
Readme: http://www.wingmanteam.com/files/Tools/ClrCalib/Readme.txt
Posted on Apr 20, 2010
1helpful
Saitek AV8R-02 not recognised by my iMac Intel OSX 10.6.8
Hi, I got this working by downloading and installing this <http://tattiebogle.net/index.php/ProjectRoot/Xbox360Controller/OsxDriver> then adding in a new device by altering /System/Library/Extensions/360Controller.kext/Contents/Info.plist in the right place adding :
<key>AV8R-02</key> <dict> <key>CFBundleIdentifier</key> <string>com.mice.driver.Xbox360Controller</string> <key>IOCFPlugInTypes</key> <dict> <key>F4545CE5-BF5B-11D6-A4BB-0003933E3E3E</key> <string>360Controller.kext/Contents/PlugIns/Feedback360.plugin</string> </dict> <key>IOClass</key> <string>Xbox360Peripheral</string> <key>IOKitDebug</key> <integer>65535</integer> <key>IOProviderClass</key> <string>IOUSBDevice</string> <key>idProduct</key> <integer>52009</integer> <key>idVendor</key> <integer>1848</integer> </dict>
Hi;How do restore the calibration screen for the Saitek AV8R-01. I have a Microsoft Windows XP.
Saitek pro flight multi panel won't work
exit present flight to general menue, minimize so you can access the "start" button then go to programms/saitek and select "lauch the Flight Sim 2004 plugin". All will work well.....exect the trim wheel acts in reverse!!
5helpful
2answers
Saitek AV8R-01 Joystick - How to install?
No download disk is required. Your PC will automatically 'find' the joystick after it has been plugged into a USB port.
You can just about play any flight sim with this joystick, jat, prop plane or helicopter. The buttons do what ever you program them to do through your game's control settings.
3helpful
AV8R manual
Joystick turned off, won`t operate
Ok... that is a VERY Easy fix... all you do is get into a plane with the kneeboard and click controls and find it!
3helpful
4helpful
4answers
Saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
Video Game Consoles & Games Logo
Top Saitek Video Game Consoles & Games Experts
Ekse
 TE5LA
TE5LA
ADMIN Canada
ADMIN Canada
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
