Washer wouldnt spin But i could play with door and it would work so i installed a new Installed new door switch now getting code 41 Is there also new door latch
The main control board thinks the door switch circuit is "open" - you would need a professional to . Is the loading door closed? No, close the door. Yes, go to step (2). 2. Disconnect the plug from J2 on the Main Control Board and check for continuity between the pins in the plug. Open, check the door strike. If good, replace the door switch assembly. Closed, replace the Main Control Board.
SOURCE: Affinity ATF7000 washer high speed spin not
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
SOURCE: Frigidaire Affinity ATF7000 - E20 error code
Thanks to the different postings on the net about a E20 error code I took apart my washer’s drain system ATF7000 to find. A pare of little girls underpants, one hair band, one plastic green gem, a golf ball sized wad of wrappers/stickers/???, and almost two dollars in coins. All caught up in the plastic strainer located inside the black rubber boot found on the bottom of the tub leading into the drain pump.
Here is how I did it: After emptying the washer of sloppy contents, I sucked as much of the water out with a shop-vac. I then turned the washer onto it’s left side gently using a couple of towels as a cushion (unplugging the washer and hoses first). From the bottom and back panel you can access the drain hose/pump/coin catch. With a pair of pliers you can remove the clamp holding smaller end of the rubber coin catch to the tub, with a Phillips screw driver you can remove the larger clamp of the rubber coin catch to the tub. From the back panel you again use your pliers to remove the clamp to the drain line, and finally with a Philips screw driver remove the two screws holding the pump to the bottom of the washer. Oh yah, do not forget to unplug the wire from the pump. Now pull the pump out with the black rubber boot still attached. Mark the orientation of the pump to the boot with a sharpie pen, and remove the last clamp. Now look inside the black rubber boot and gently remove the plastic basket inside, there you will find the treasures that just wasted the last hour of your time. Now reveres those steps, reinsert the half washed clothes, and enjoy your new machine.
Thanks again to everyone that has posted before me, otherwise I wouldn’t have known were to even start looking. I hope this helps someone.
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
SOURCE: I have an Frigidaire Affinity
Hello
& Welcome to FixYa E41
error indicates that the problem is with door lock assembly, it is displayed
when the control board thinks that the door switch is open. To solve this
problem you have to remove the door lock assembly and measure the resistance of
the PTC. If it reads open then the door lock assembly needs replacement
however, if the reading is around 1500 ohms then replacing the control board is
recommended repair. Please get back to me if you have any other questions. Kevin
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
