OK! Don't worry! You do have chances to
restore all your lost photos back from this formatted memory card as long as
you've not overwritten them with anything new. Here are steps for you to
restore all your wanted photos back successfully:
1. Stop using this camera memory card right
now in case that any new file on it may overwrite your deleted files.
2. Insert this camera memory card to your
computer via a card Reader.
3. Download a camera memory card data recovery freeware to retrieve all your
lost photos back.
This professional data recovery freeware
has helped many people around me restore their inaccessible data off from a
phone/camera memory card or hard drive. It could be a good choice for you to go
on.
Try to read more detailed information of
this memory card data recovery freeware here:
http://blog4mark.blogspot.com/2012/12/photo-recovery-after-delete.html
4. Do not save or back up all the restored
data on the same camera memory card in case of any data loss.
If the pictures were on the memory card then they were never in the internal memory and cannot be recovered from there.
However, if you haven't done anything to the card since then, you may be able to recover at least some of the pictures. Do a Google search for "data recovery software" and select a program for your computer and operating system. Put the memory card into a card reader attached to your computer and run the program.
SOURCE: cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
SOURCE: internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
SOURCE: won't read memory card
i hvae had this happen many times... ok this is what you will need to do. take the memory card out and look at the little brass things and clean them with something thats cotton. repeat this till it reads. i hope this will help.
SOURCE: Transferring photos
Had exact same problem. Here the solution:
Choose playback, then "Mode" button will bring you Slide show options menu. Navigate to Image/Sound Copy Item.
You'll find options to copy from/to internal memory/flash card there
SOURCE: Memory card fails to format
Try to buy a card reader and format the card from your computer first. If the camera is brand new and still able for return, return it.
