By misaligned do you mean the door hits the inside liner of the
freezer? If so then loosen the three screws that secure the top hinge
and reposition the door so it clears the freezer liner, then retighten the screws. If by misaligned you mean the door is warped so that the door
dosn't fit tightly all the way around then you need to loosen all the screws under the door gasket and then twist the door so it seals evenly all the way around the door. (Hint loosen the screws just enough so
the door will stay aligned after you twist it). Good Luck
