You can try to do a system recovery on your PS3. this will set your PS3 back to factory settings as the settings may have been changed during the use. Here is the process in which you can do a system recovery.'
PS3 Recovery Menu
Place the PS3 in standby mode
Press and hold the power button for a couple of seconds, you should hear a beep
Keep a hold of the power button for a couple more seconds, the PS3 should shut back down to standby mode
Once this happens, press and hold the power button again for a couple of seconds, waiting for 1 single beep.
Ignore this beep and keep it pressed until you hear 2 consecutive beeps, release the button.
I think you choose option 3 and then repeat and choose option 4. Once you are done with this, try out your PS3.
PS3 freezes means some hardware errors occurred and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn : DIY PS3 Repair Guide Not only such freezing problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
There is a problem with firmware 3.00 and Uncharted. Update your firmware to 3.01 by going to the [Settings] menu and selecting [System Update]. The update is optional.
Make sure the console is out in the open. It needs to vent. Don't place it in a confined area. Make sure any vents on the console itself are not blocked or covered with dust. Sounds like it is overheating.
