Question about Akai PT5492S 54" Rear Projection Television
Red led comes on tv wont
Turn on with remote led comes tvwont
Posted by royal_bret on
Seth
    Problem Solver:
  • 7 Answers
Might just be the fuse (a 1.5 inch glass tube inside the back panel by the power cord ,)
BE VERY CAREFULL IF YOU DECIDE TO CHECK IT!!!!!!!!!
make sure that THE TV IS UNPLUGED,
USE A RUBBER HANDLED FLATBLADE SCREWDRIVER TO POP THE FUSE OUT
DON'T TOUCH ANYTHING BUT THE FUSE ITSELF!!!
if its not that- its a transformer and not worth fixing
sorry but I'm taking NO RESPONSIBILITY if you zap yourself
i'm only telling you what I would do to check it without killing myself
Posted on Aug 22, 2012
Need a code to program an innovage jumbo remote to an RCA tv. nothing fancy just the tv code please
The Innovage Jumbo users manual lists over two dozen RCA TV remote codes. They are:
000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
If you can't be bothered to enter each of those codes one at a time, you might consider the auto-search function.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 09, 2009 | Innovage Jumbo Remote Control
I have a jumbo universal remote,how do I programit to an rca tv?
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Nov 23, 2009 | Innovage Jumbo Remote Control
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
  1. Turn on your TV.
  1. Turn on your TV.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Oct 31, 2009 | Innovage Jumbo Remote Control
I need the codes for the jumbo innovage control for an advent tv.
I don't see Advent TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. the LED light will turn off.
Oct 11, 2009 | Innovage Jumbo Remote Control
I need the codes to install on a new tv
To search for the control codes that will work on your new TV, follow these steps:
  1. Turn on your TV.
  5. Once the TV turns off, press the ENTER button to store the code. The LED light will turn off, and your remote is programmed for your new TV.
Hope that helps.
Oct 07, 2009 | Innovage Jumbo Remote Control
I bought a universal jumbo remote and i followed instructions i to program it to my Jvc tv but it does not work can u help?
Make sure you try every code in the list for your JVC TV.
The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Sep 24, 2009 | Innovage Jumbo Remote Control
Need code for Innovage jumbo universal remote for a rca tv
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Sep 17, 2009 | RCA TruFlat 27F520T 27" TV
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
Akai PT5492S 54" Rear Projection Television Logo
Top Akai Televison & Video Experts
Ekse
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
