Does not drain properly at bottom of the tub. In the Tub is empty, but in the bottow seems to be standing water, how do i release the water? I replaced the hoses and used baking soda and tried to drain, no luck. Seems after a few days washer starts to reak smell. Any ideas of ripping the washer open to dispose the water? Help Please
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
SOURCE: eco smart won't drain, smells hot
hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
SOURCE: GE Washer agitates when I try to fill it up with water,wont fill
You have a bad water level switch or a clogged plastic hose that goes to the water level switch.
Use a putty knife to open the front panel. The clips are at the top right and left sides just below the top lid. Push in on the clips and pull out on the panel.
On the left side of the tub you will see the air dome with aplastic hose connected.
Remove the hose and insert a small wire into the air dome hole to clean it out ouf soap scum. Then, blow through the hose and listen for a faint click in the water level switch. Also check the hose for a hole or being pinched.
The set the timer for spin and run a spin cycle then retry the water level and wash cycle.
SOURCE: 5 month old Whirlpool Cabrio washer has moldy
Smelly washers are common. Cabrio washers are HE and therefore use less water. By using less water, it doesn't rinse ITSELF as good as an older non-efficient machine. Things you can do to solve the problem. Buy a cleaner from Whirlpool called Affresh. It's 3 tablets that you throw in the washer without clothes and run it on the longest heavy duty cycle possible. Use the hot water setting and the longest duration. For existing smells use all 3 tablets. Then use 1 tablet every month to prevent reoccurring odors. You can also try the same type of cycle on hot water with a half of a gallon of bleach in the tub, or try it with a half of a gallon of vinegar. One of the 3 should do the trick.
For these suggestions..do you know how to find these problems? Not sure how to dismantle my washer.
