Question about Sony Cyber-Shot DSC-P73 Digital Camera
"NO FILE IN THIS FOLDER" message is on & I can't take any pics
The message "NO FILE IN THIS FOLDER" comes across the screen & it won't allow me to take any pictures. Also no matter what settings I have it on, the camera just shuts off. Is there a way I could fix the "NO FILE IN THIS FOLDER" message? Thank you so much for any help you may be able to provide.
Posted by LAVAY HART on
5 Related Answers
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: My camera displays file error cannot view pictures
Data is corrupted while it was being stored. Format memory stick through Format option in camera Menu.
Posted on Apr 14, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: my sony dsc-s730 camera comes up with file error
Format memory card and check, if problem exist then replace memory card in camera.
Note: Format will delete all photo data on memory card so copy photo files before format.
Posted on Jun 21, 2009
Anonymous
  • 31 Answers
SOURCE: White lines appearing on display after picture is taken
I have the same problem, and upon looking into my problem, i recall reading that Sony had used crappy glue in which they attached the CCD to the inner guts of the camera, and when that deteriorates, which doesn't take very long, then your pictures will have lines through them.
I think i remember reading that Sony said they will replace all cameras within 2 years of their manufacture. Call Sony's troubleshooting and support and they may replace it for you.
Hope i helped solve your problem.
- Josh
Posted on Oct 20, 2008
Mitesh Kr Anand
  • 497 Answers
SOURCE: dropped camera dsc-w120.
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
Press the Home button on the Camera. Then, select the SETTINGS -> MAIN SETTINGs -> MAIN SETTINGS 1 -> INITIALIZE -> OK.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
If the issue still persists then Service may requires to resolve it.
Posted on Aug 22, 2009
Ty Price
  • 11967 Answers
SOURCE: cannot find the following folder for media file import
It's very difficult to follow exactly what you did. The easiest solution may be to use a card reader to download your pictures to a folder you create on your desktop. Next time, don't overload your card.
Posted on Oct 07, 2009
Ipad PNG pictures can't copy to harddrive - parameter is incorrect
you can try using the app "Shareit". it will give you an option to transfer files from ipad to computer.
Sep 05, 2017 | Tablets & eReaders
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
Save or move something to the SD card
Here are the steps to copy something from the internal memory to the SD card:
  1. Use the File Manager app, and select the internal memory (second icon from the left at the top of the screen).
  2. Select the file you want to copy, and keep your finger on it for several seconds until the 'File Operations' menu pops up.
  3. Select 'Copy File'. Near the top of the screen a small message will show in red, saying 'Holding [file name]".
  4. Select the SD card (third icon from the left at the top of the screen) and the folder where you want to save the file. Keep your finger on the folder name for a few seconds until the 'File Operations' menu pops up.
  5. Scroll down the 'File Operations' menu until 'Paste into Folder' appears, and tap it.
  6. You should see a success message.
You can move or copy things from the SD card to the internal memory also.
Aug 26, 2012 | Mach Speed Trio 4GB 7" Trio Stealth Pro
How to open Outlook 2010 email files backed up to a CD?
You will need to import the data from the PST file back into outlook . It should go into a personal folder
After this process you can then copy the files into your email inbox or leave them in a personal folder or create a personal folder on a server mapped drive and then import email data to this folder so it gets backed up hopefully on the server. If you bak up the server..
https://support.office.com/en-us/article/Import-email-contacts-and-calendar-from-an-Outlook-pst-file-431a8e9a-f99f-4d5f-ae48-ded54b3440ac
May 24, 2017 | Microsoft Outlook 2010
Problems installing Neat Receipts
You need to install Microsoft SQL Server Compact 3.5 Service Pack 2 from MS web site:
http://www.microsoft.com/en-us/download/details.aspx?id=5783
Steps:
1. Download installation package from above link and save them to the desktop or other folder
2. Start that .exe and unpack to some folder on your PC (or that same folder)3. Open that folder and run BOTH installations for Windoxs x64 PC - first start:
SSCERuntime_x86-ENU.msi and then
SSCERuntime_x64-ENU.msi
4. This would install necessary SW and then you could re-insert Neat CD to start the installation which would proceed now.
Mar 06, 2012 | NEAT Receipts Mobile Scanner
Coolpix s8100 technical support my camera dropped and broke so I was given a replacement. When I insert memory card from other camera and try to take pics, a message reads, "file contaisn no image...
First, get a card reader (they're very cheap) and use it to download the pics from the card. Then, re-insert the card into the camera and go into the menu and find "format"....follow the on-screen instructions to completely erase the card and optimize it for your new camera.
Oct 15, 2011 | Nikon COOLPIX L18 Digital Camera
I live in Italy. I tried to download Microsoft Security Essentials, but continue to get the message that the Microsoft.com website is unavailable. I made a copy of the Microsoft Security Essentials folder...
Hello, good day.
1. Uninstall any existing antivirus including anti-malware software from your computer.
2. Remove the MSE folder from "Program files" folder that you copied from your friend.
3. Restart your computer (shutdown and wait for 30 seconds, then switch on your computer).
4. Logon with your usual login credential.
2. Download MSE. Browse this link http://www.microsoft.com/en-au/security_essentials/default.aspx.
3. Click the download link and follow the instruction.
This should complete your installation.
Aug 22, 2011 | Microsoft Security Essentials
I'm getting a message "cannot
That probably is just a "Back-Ground-#1' bitmap image-file.
Does your camera work without this file?
Can you create a "bitmap" file (using the PAINT program in the ACCESSORIES folder) and call it 'BG1.bmp', and store in into that 'corona' folder?
Aug 18, 2011 | Gateway MT6705 Notebook
Last night my friend sent me photos from our HS Reunion,when i clicked to download everything was fine all the way thru to when i clicked on open.I clicked on open the file started to download but the only...
You should of got an error message after it wouldn't open. Pls try to post it so we can see what happened. Sometimes the picture will be open down at the bottom of the email which you may not notice because your trying to work with the attachment. If you find them at the bottom, (it matters which format they come down in) right click/ copy/ go to my pics/ paste or save pic as/ then select destination folder. You can also click on the pic and it will ask you what you want to do. Anything that goes wrong 99.9% of the time will give you the error message. Very Important!!!
Dec 17, 2008 | Computers & Internet
Sony Cyber-Shot DSC-P73 Digital Camera Logo
99 people viewed this question
Top Sony Cameras Experts
 Larry
Larry
 MikeWang
MikeWang
Paul Green
Are you a Sony Camera Expert? Answer questions, earn points and help others
