When you connect it to your pc which file do you download ringtones into?
SOURCE: install games on samsung D900, says unsupported file format
find another one ,, that say's for your fone games only.. coz if you dwnload not supported either it not for ur fone , or it was corrupted.
Well it certainly is easy but people have made it difficult you don`t need to do much ok
I`ll provide you with easiest steps ever
1.download some games with both formats and put them in the same folder ok both extensions of the files would be like
EXAMPLE:- Driv3r.jad and Driv3r.jar
2.Also download Softick PPP 2.21*** just write it on google you`ll get it
3.Get A Bluetooth Device or Blutooth Dongle and connect it to PC, remember the blutooth icon below the left side of the task bar goes blue....
3.Now Activate Bluetooth on your Samsung SGH-D900 and go back to the main screen and enter the code #*5737425# and you`ll get a new menu open,the headline of that menu would be JAVA SERIAL
and Below that would be 1.PPP UP 2.Serial Download and 3.RUN TCK
4.Now after the softick is installed open it and an icon will appear on the screen on the taskbar below
right-click it and activate it be patient while it would be activating you`ll get a on-screen msg on your mobile that`ll be SERIAL CONNECT WITH DEVICE and you should accept it and then look back on the same menu of JAVA SERIAL then click PPP UP and it`ll take you to two more options just click BLUETOOTH and you`ll be headed back to JAVA SERIAL MENU.
5.Now You Need To Download The SAMSUNG JAVA UPLOADER similarly write it on google and you`ll find it easily now open it and A window will appear go for ADD
a window will open remember it only adds jad files don`t forget to get the jar file for the same prog.
and then add the jad file on the same JAVA MENU after all steps click serial download
GAMES WOULD BE INSTALLED AND ENJOY
Remember just after a game is installed repeat the same step but you would not go for PPP UP just go for serial download and its all done
SOURCE: My cell phone wont read '.jar' files
copy the .jar file to your phone using either Phone Suite or windows explorer (remember where you put it ...). In your phone menu open the file explorer and locate the file. Select the file and in 'menu' chose 'install' et voila.
SOURCE: I want to download pictures from Sumsung M320 cell phone
You'll likely require a cable and software to do so. Susteen is a supplier that offers a kit with both, and can be purchased at your local electronics retailer.
I've written an article that might supply other solutions:
http://yourmonstersofmobile.com/how_to_for_cell_phones/move_music_files_and_pictures_from_your_cell_phone_to_your_computer.html
