My phone was turned off for a day now its on back its requesting puk/pin1 code....................i cant call customer care because i'm in another country ( and its not going through )
SOURCE: unlock blackberry
you can unlock your Blackberry 9800 torch with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry. get your Blackberry 9800 Torch Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
SOURCE: forgot my phone lock cod for blackberry torch
I will help you to remove the Security code lock from the Phone,You can use the security unlock code to Unlock the Phone ,you can get the Security unlock code from the site
www.classicunlocking.com and Unlock it.
SOURCE: mep code 0 left blackberry 9800 torch .now what
Dear friend, if your Mep counter is 0. you need to cable process to reset your Mep counter . after that your Blackberry 9800 unlock . and no need to unlock again. use any Gsm sim card in your Blackberry 9800 torch.Good luck.
SOURCE: blackberry 9800 torch blacklisted
you can Unlock your Blackberry 9800 torch with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry 9800 torch. get your Blackberry 9800 torch Imei Unlock Code . and use any gsm sim card.
SOURCE: need puk code for blackberry torch 9800
Hope it was set a password or a security code on the cell-phone.
And Regarding your PUK code please contact your service provider. The PIN code supplied with the SIM card protects the card against unauthorised use. The PIN2 code supplied with some SIM cards is required to access certain services. If you enter PIN or PIN2 code incorrectly three times in succession, you are asked for the PUK or PUK2 code. If you do not have them, contact your service provider. The module PIN is required to access the information in the security module of your SIM card. The signing PIN may be required for the digital signature. The barring password is required when using the call barring service.
thanks for using FixYa
1 - Switch ON your Blackberry 9800 Torch with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry 9800 Torch should then be unlocked.
