Fuel line in tank has rotted out. Need to replace. also lines to purge valve.
Cut one end of the new hose down to 1/3 about a 1/2'' long slide a wire threw the tank and out of the gas cap opening slide the new hose trimmed end and pull the wire and hose back til the trimmed end sticks out pull the hole threw connect the filter to the end and pull into place trim and connect to the carb the return side do the same way just without the filter
Posted on Sep 04, 2012
SOURCE: NEED A FUEL LINE DIAGRAM FOR POULAN 2250
The smaller size line comes out of the tank, leave enough to install filter on that line in the tank, this line goes to the intake side( I think it is the right side of the carb when it's mounted in the saw), of the carb. The other smaller line goes from the other side of the carb to the primer bulb. The larger line goes from the other side of the primer bulb back to the tank, it only has to be pushed in the tank about 1/2 to 3/4 inch. The large line goes in the tank in the hole on the right side unde the carb. The primer bulb has different size nipples. I just put these on mine, it's hard to get the lines in the tank, I sprayed mine w/wd40 and just pushed them in until I could pull it with some needle nose pliers or hemostats.
Posted on Apr 29, 2009
SOURCE: installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Posted on Sep 14, 2009
SOURCE: fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
HTH
Lou
Posted on Oct 24, 2009
SOURCE: gas line diagram for poulan 2050 2.0 CI '97
Gas line diagram for poulan 2050 .
Posted on Oct 25, 2009
SOURCE: I have a Poulan 2150 2.1 chainsaw. I have no
An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
“2150 Gas Saw Type #” (the dash number from your serial number). May also be Predator or Woodsman.
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
Take good notes and a some digital photos with as much undisturbed detail of hoses and routing as possible.
Try your local chainsaw seller/mechanic for fuel hose. Take a short length sample, there may be different size hoses. All need be fuel resistant.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Posted on Oct 30, 2009
EVAP System Incorrect Purge Flow (Stuck Open)
Possible Causes:
Charcoal canister is damaged, clogged or restricted.Purge solenoid control circuit open, shorted to ground or power.Purge solenoid power circuit is open (check the relay or fuse).Purge valve vacuum line is clogged or contains water or debris.Fuel filler cap loose, cross-threaded, incorrect part or damaged.Fuel tank or fuel tank sender assembly 'O' ring is leaking.Fuel tank vapor line(s) blocked, damaged or disconnected.PCM has failed.Here are the causes.
