Manual
SOURCE: my goldstar ghd30t7 just stopped
If it has no power at all then its the problem of power supply to the machine.The main control board in the Dehumidifier needs to be checked.But if there is power to the unit and its not working then check if the fan in the unit starts or not,if not then its the fan problem.Give a little push to the fan by hand manually and check if it starts spinning.,Take any wooden object to push the fan with power on.also check if the drain hose is getting blocked in the unit.
Thanks. Keep
updated for any more query. You can rate this solution and show your
appreciation
