I unplugged the 2 cables on the back of the scanner and did a power cycle. Plugged everything back in, even tightened the cables with a screwdriver to make sure they are seated correctly and I am still getting the error message. I can still print but can't do anything else (copy or scan). Help!
Who ever thinks it is a software (as in computer driver) problem, you need to read what the problem was and the steps already taken to solve.
As you can see it is clearly to do with the cables and is a common problem with these copiers. We have three in shop right now with same issues!
The areas to look at are the cable connectors for damage, if you are technical you can open the adf plastic covers, and follow your scanner cables make sure no "pinching" has occured.
Other than that you can try factory reset, although this rarely works for this problem.
Refurbished units are retailing arond $350-400 all over google.
SOURCE: Scanner and copier not working
You have a problem with printer need to contact Lexmark your scanner is probably broken.
SOURCE: Lexmark X1185 (print trio) does not scan or copy since upgrading to Vista
I had the same problem. Fixed it by reinstalling the drivers for the motherboard (USB drivers in particular). Hope this helps.
Bill Scott
Dixmont, ME
SOURCE: lexmark x2500 err msg: UNABLE TO CONNECT
What you will see
When trying to print, you get a communication error; the device
is correctly detected in the Device Manager, the firewall is not
blocking any files and you can scan using the All-In-One Printer.
Explanation
Any PC using the AMD USB architecture is preventing the printer from printing when connecting via USB.
What to do
Follow the specific steps for the PC manufaturer below:
Dell Studio 1536:
IMPORTANT: Do not replace any hardware, before performing the following steps:
Step
Action
Go to Control Panel
Go to Programs and Features
Uninstall AMD USB Audio Driver Filter
Note: Uninstalling this USB audio driver doesn't cause any impact for systems with Vista Service Pack 1 installed
Acer Aspire 5530, Extensa 4130, Extensa 4430, and TravelMate 4530:
There are files available to
address printing problems when connected to a USB printer or
multi-function printer, for Windows Vista and Windows XP.
Please go to the Drivers and Downloads area to get the file appropriate for your operating system and unit.
US Customers:
http://www.acerpanam.com/synapse/data/7117/documents/USBFilter107_Vista_Setup.msi
http://www.acerpanam.com/synapse/data/7117/documents/USBFilter107_XP_Setup.exe
EMEA Customers:
ftp://ftp.work.acer-euro.com/notebook/aspire_5530/vista/Drivers/USBFilter107_Vista.zip
IMPORTANT: The
third-party products discussed in this article are manufactured by
companies that are independent of Lexmark. Lexmark makes no warranty,
implied or otherwise, regarding the performance or reliability of
these products.
Still need help?
If you need additional assistance, please contact Lexmark Technical Support. NOTE: When calling for support, you will need your printer model/machine type and serial number.
Please call from near the printer and computer in case
the technician on the phone asks you to perform a task involving these
devices.
I hope it helps!!!
SOURCE: Lexmark x3550 will not scan 'Downloading Application List" and "
Had the same problem. Installed the most recent drivers. OK now. Good luck. - Kakou
