Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
The problem is with rotor assembly of the drawer that is causing the F2 error. Turn power off. Empty water using a small container and towel to dry base.
Remove the washer arm and drain filter sump cover. Twist the rotor at the base out from the socket gently but firmly.
Clean the cavity and check the rotor for damage. Put everthing back in and turn power on.If F2 does not go away then replace rotor.
Posted on Aug 22, 2012
SOURCE: Hi I have a DD603
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
Posted on Jun 02, 2011
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hello &
Welcome to FixYa
F2 is a drain error in your washer, if
the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the
drain pump filter, you can take out three torx screws from the bottom front
panel and then clean the area completely, lift up the cap to clean the filter.
If the error returns then check the drain pump if it is not working then
replacing the pump is recommended repair. Please get back to me if you have any
other questions.
Kevin
