SOURCE: cassette players jammed
actually you can not lubicate the cassette players. it has to do with a belt inside. your players may need to be demagnitized. i would go to radio shack or electronic store and try a cassette cleaner/demagnitizer and see if that solves the problem. i would even try different batteries or a ac power adapter if you have the plug. some batteries make units run slow. i would even get a can of dust cleaner that you find in the electronics section. you spray it in and it cleans the inside of the dust that may be inside.
SOURCE: When tape is inserted the unit starts beeping and
The beeping indicates that an error has occurred and that the unit has been disabled because operation could damage the unit further. To determine what the problem is- Turn unit off. While holding the STOP button, turn back on and continue to hold the button for 8 sec, then let go. Press display and you will get an error code on the monitor, for instance, C:21:00 error code (the most common code I get) indicates a condensation problem. If this is the code you get then leave the unit open in a dry place for 24 hours or so, and it should dry out the dew sensor and clear the code. The unit will hold up to 6 error codes in the order that they occur, rotate the wheel to cycle through the codes. Codes are displayed as - C:XX:XX. If you get a code other than C:21:00, then google the code,(Sony C:XX:XX) and the description will probably come up. Good luck.
SOURCE: loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Testimonial: "saved the deck - I was going to replace it! fast response too! Thanks"
SOURCE: Unit accepted cassette, won't eject
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
