Daisy 840B Grizzly Youth BB Air Rifle Kit Logo
Posted on Aug 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My grizzly 840 loses air when i pump it
When you pupmp you can here air leeking
Paul Nielson
Level 2:
New Friend:
  • Expert 92 Answers
  • Posted on Aug 20, 2012
Paul Nielson
Expert
Level 2:
New Friend:
Answers
92
Questions
Helped
17705
Points
202
You need to pull it down/apart & install new "o" ring
  • Anonymous May 14, 2013
    which one though?..,.theres 2: one attatched to the pump and one in the valve...(im having the same problem)
  • Paul Nielson
    Paul Nielson May 19, 2013
    It would be best to replace both o-rings at the same time, if one is worn then the other might be on its way out too
Daisy Grizzly 840 won't pump up and shoot
Bad seals in Daisy bb and pellet guns cause this. Get the seals replaced in it and it will work. Look on the web for service on BB guns.
May 05, 2018 • Firearms
My dewalt 2 gal air compressor model D55141, when on hisses inside the pump housing. Sounds like a leek. Some pressure builds.
More than likely is leek. Must get to it to look at connections and air line to find out If slow probably would hear it. But loud you will find it. Tighten connections if it's there, other wise replace line
Where can I find a Daisy Grizzly Model 840 Bb Gun Repair Manual Free
Recommend an eBay or Google search or contact Daisy directly here
Dec 18, 2017 • Daisy Toys
When riding my 2011 Yamaha grizzly 700 about 1/2 throttle it shuts down and when I get in water or mud it like it loses power what would it be
Hi Curtis:
Considering the age of the machine I'd be looking at basic maintenance first. Things like air filter, fuel filter, carb condition, spark plugs, oil and oil filter change. Then start thinking about valve condition and clearances.
Vehicle is losing water. Already changed water pump. Unsuccessful at resolving issue.
are the carpets in side dry might be leeking from heating unit cylinder head jackets leeking you would see the water running down the sides of the engine split hoses leek in radiator or expansion tank hoses how much does it lose has the mechanic done a pressure test there could be a crack in the block or cylinder head a pressure test would find all these leeks
Pumping does not build preasure, every pump leaks out, help
If you take apart the pump mechanism you will see a little black o ring that has dried out either Reuben or replace and add a little oil to the mechanism to keep lubed and it will work fine.
2003 yamaha grizzly 660 4x4 atv, right side rear axle/cv joint came lose at differential
Yamaha Grizzly 660 2002 2008
get one of these..If you are going to try the repair yourself....
.this is serious, ....
there MIGHT be damaged components that need to be inspected by a professional.
5helpful
Gun fires weakly and sounds like air escapes after pumping
Sounds like you have a problem with either the valve leaking or possibly the piston head. I know by expierence that pumping the rifle more than once wont cause failure, so the issue here is not your fault. If the rifle is under warrenty then return it and get a replacement. If not then call Daisy and talk with their quality guy. He has helped me out a few times.
Aug 12, 2009 • Optics
2answers
I have a dodge Intrepid 1993 that has been siting for two years.When i started it up and let it run for a while it started leeking water.and i can't tell where its coming from. Is there a diagram so that i...
the water pump is behing a metal plate that you you would have to take off in order to look at it. if you have the 3.5 motor and are losing water then thats where it wil most likely be coming from,
Top Daisy Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Daisy Optic Expert? Answer questions, earn points and help others
