Volume control only works on internal speakers. must adjust external speakers through volume volume on external volume control
There is no control for this in the TV. You must do it with the volume control of the external amp.
Posted on Aug 21, 2012
Aug 10, 2013 | Computers & Internet
Apr 11, 2013 | Toshiba Tecra A2 Notebook
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 06, 2012 | HP Compaq dc7600 Small Form Factor PC...
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope it helps
Sep 22, 2011 | Logitech X-230 Computer Speakers
Mar 25, 2011 | Computers & Internet
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
Nov 15, 2009 | Cell Phones
Oct 08, 2009 | Apple MacBook Pro Laptop Computer with...
May 21, 2009 | HP RT987UAABA - HP Compaq dc5700...
Oct 05, 2007 | Logitech Z-5300 Computer Speakers
Jan 18, 2016 | Sanyo DP42849 42 in. HDTV
643 people viewed this question
This model has no switch (internal/external). External speaker system must utilized seperate volume control.
