Question about Element Electronics ELCHW261 26 in. TV
My LCD tv makes a buzzing noise but won't turn on
Posted by Duane Tabinski on
    Top Expert:
  • Element Elec... Master
  • 76,416 Answers
Check its back-light inverter board. Replace it.
Posted on Aug 21, 2012
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
My GPX tv/dvd combo is making an intermitent 'buzzing' sound,anyone know how to fix it?
Is the sound coming from the speakers? (do you hear it with the sound turned off)
Either an audio problem if heard only with sound up or if a buzz with sound off it is a coil or transformer on the circuit board vibrating hard enough to produce the noise.
Both are fixable but require different tactics to resolve.
Mar 14, 2012 | GPX Televison & Video
I have a 32 inch lcd magnavox tv. when i try to turn on the tv it goes right back off within 2 to 3 seconds. its fairly new tv like 3 yrs old. any idea?
Check your power supply. Take it apart and see if the compositors are all in good shape. If they are popped, puckered or oozing stuff out of them then you are going to have to replace your power supply. It also could be a bad inverter. Is there a buzzing noise before it shuts down? Has been doing it for a while and now won't come on at all now?
May 28, 2011 | Philips Televison & Video
My 32" Philips LCD TV makes a annoying buzzing
The main cause off buzzing from these sets is the transformers on the psu. This can be solved by sealing the transformers with a sealant spray.
Jan 21, 2011 | Philips 32PF5531D 32 in. LCD Television
Buzzing noise
you have to replace a capacitor in powersupply
c208 2200uf/16v
Apr 19, 2010 | LG 42LC2D 42 in. LCD HDTV
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Samsung lcd-tv is making a buzzing noise
I have been having that same buzzing sound. It happens when you turn on the energy saver feature on the tv setup. Just turn it off. Smooth
Jul 15, 2008 | Televison & Video
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Element Electronics ELCHW261 26 in. TV Logo
651 people viewed this question
Top Element Electronics Televison & Video Experts
Mike
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
