Question about Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator
Hotpoint rfs60 salad crisper freezing
Changing temperature makes no difference
1 Related Answer
Anonymous
SOURCE: hotpoint rfs60 high temperature light staying on
Had the same problem with the same model fridge, had to get the engineer out from hotpoint said it was the gases and their was a blockage in it. could not be fixed.
Posted on Mar 09, 2010
Can we get parts for proline fredge freezer model pf200w
You can get that part here:
http://www.partmaster.co.uk/proline/pf200w/salad-crisper/catalogue.pl?path=67607,126607:126606&model_ref=2008318&refine=salad+crisper
May 24, 2014 | Video Game Consoles & Games
Food freezing in crispers in ge bottom freezer fridge
Check to see if the fan is working...put a thermometer in the refrigerator and make sure the temps are between 33-41 degrees F.
Dec 18, 2013 | GE Refrigerators
What is the best temperature to keep the refrigerator ( Hotpoint)
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:SIY_RFFRIDGETEMP
What should a Hotpoint fridge temperature be?
Your Hotpoint fridge is designed to operate at a temperature ranging from 0.5 degrees in the coldest part up to 5 degrees inthe warmest part.
As warm air rises and cold air falls it is safe to say that the best way to store your food is to place it in the most appropriate shelf compartment, as shown in the diagram below.
  • Zone A - Cool Dairy Products, Cheese, Butter, Margarine, Low Fat Spreads, Cooking Fats/Lards, Preserves, Jams, Curs, Marmalade, Salad Dressing or Sauces
  • Zone B - Colder General Food Storage
  • Zone C - Coldest Meat, fish & poultry, Pre-cooked/chilled food
  • Zone D - Salad Bin, Vegetables, Fruit and Salad Items
May 08, 2011 | Hotpoint Refrigerators
CONDENSATION ON BOTTOM SALAD CRISPER SHELF OF A WHIRLPOOL INTERGRATED FRIDGE
cold,damp air,condensates on warm shiny surfaces(bathroom mirror),try putting kitchen towel under the crisper...(why they put crispers on bottom of fridge instead of on top of the cooling coils at the top of the fridge ???)
Mar 29, 2010 | Refrigerators
What is causing water to build up inside the refrigerator section? there is water in the crispers and on the shelves.
A condensation problem inside a fridge, normally means either, you are puting uncoverd food /or food that has a high water content (i.e.salads) into the fridge, which may be warmer than the inside temperature of the fridge, hence condensation(leaving the door open too long has the same effect)only remedy is paper towels in bottom of crisper so that salads dont go soggy.and wipe out fridge as often as needed.
Mar 10, 2010 | Whirlpool ES5FHAXS Side by Side...
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Salad in salad tray keeps freezing
contact the people who made the frig, sounds like a service call might be needed. you are paying for food that is destroyed, the service guy may save you money in the long run.
Oct 03, 2017 | Refrigerators
Hotpoint rfs60 high temperature light staying on but freezer still works although maybe not to full potential
Jun 19, 2009 | Hotpoint RFS60 Bottom Freezer Refrigerator
Water beneath the salad bins
check the freezer section if its all frost up at the bottom part. the evaporator is freezing and transfering the coldness at the bottom part that sweats water beneath the salad bins. heater cycle is not working properly...
Feb 12, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator Logo
Top Hotpoint Refrigerators Experts
Dan Webster
Dan Webster
jdthefixer
Michael Thomas
Michael Thomas
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
