When I step on the scale I see L6. I put is a new batterie but the same code appears. I don't know what L6 means.
SOURCE: E"E" reading
From what i have seen EE means overload warning, I looked on the website your scale has a lifetime warrenty on it i would recomend calling customer service @
For Customer Service: 800-289-0944 before messing around with anything.
SOURCE: When you step on the scale the readout says
Yes it means battery needs replacing. Check oringinal papers that came with scale to see if you need to order special battery. Otherwise go to a battery store that recharges batterys. They usually carry most makes. Take your battery with you so you can match right one.
SOURCE: I don't have a manual. My scales have been
I don't have a manual. The readout is in kilos rather than pounds some of the time. How can I get it to read in pounds all the time? Also I replaced the batteries. Are they supose to be both with + up? I have a replacement heart valve so I don't want to know body fat. How do I make sure it is off?
