RCA MM61110 61" Rear Projection Television Logo
ralph brown Posted on Aug 20, 2012
I have a rca mm61110 rear projection tv
When I turn tv on it go's from 0-99. Then it clicks off. after a couple secs. It turns back on and rolls thru the channels again,
5 Related Answers
Anonymous
  • 398 Answers
  • Posted on Aug 30, 2007
SOURCE: RCA 52 inch TV (turn on problems and channels rolling) HELP!
Your set uses the 195 series chasis. The only thing I can think of which would make the channels scroll by themselves is a contaminated PC board and pushbuttons behind the buttons on the front of the set. This is usually the case when spray cleaner or some other fluid is sprayed or spilled on the screen, and it drips down onto that board. To prove this, remove the back cover and on the top of the main chassis, where the top of the picture tubes are, is a small PC board with the remote reciever and a couple of jacks. The smaller jack is for the speakers and the larger jack is for the front panel PC board. Unplug the larger connector which goes up to the front PC board and then turn the set on with the remote. If the set works normally, the front PC board will have to be removed and cleaned or repaired (or just leave the jack unplugged and work the TV from the remote only). If you do not have any experience working inside projection sets then allow a qualified tech to handle it for you.
Louis faenzi
  • 133 Answers
  • Posted on Mar 04, 2008
SOURCE: Rear Projection TV P52770EB
You could have a few problems . If the front display light flashes only it could be you need a new deflection module . Also the HV block may be bad with it . If you have no front display light when you turn it on it could be the above problem or the signal board could be bad . The signal board would cost the most to get repaired due to it costs more. You would need a meter to check certain testing points to confirm which module is bad . Or call around to see who has the cheapest rate on an estimate to check out your tv. deflection board and hv block est $250 to $300. Signal board $300 to $350. Maybe more if you had a service call if you could not take it to a repair shop. Good luck
Anonymous
  • Posted on Apr 15, 2009
SOURCE: rca rear projection tv has sound but no picture. clicking noise coming from the back.
replace the lamp.
Anonymous
  • 952 Answers
  • Posted on Jun 19, 2009
SOURCE: 52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
TONY BIGNELL
  • 147 Answers
  • Posted on Nov 05, 2009
SOURCE: I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
How do i put in a new lamp from the back
remove the cover and the lamps should be visible to replace they are like big bulbs
4helpful
2answers
My rca p52960 tv will not turn on at all. What can
I would disconect the front control panel you can do it by opening the back of the unit on top of the light box there is a couple plugs just unplug the one going to the front panel then try to turn it on with the remote
Wont turn on, power light for 2-3 sec, squeals for 1 sec,
Hi
you have defective power oscillation from the inverter section..
Thanks!
CONVERGENACE ISSUE?
If you wish to get more details visit the site linked here. Convergence procedure to PTVs are given. http://electronicshelponline.blogspot.com/
Tv wont power up ?
TV turned off and will not turn back on.
RCA MM6110 The TV is on but I am not getting a picture.
Have you tried resetting the cable box by unplugging it for 5 sec. and plugging it back in? (power cable)
RCA MM61110 Problems
I took the back panel off and noticed that one of the cooling fans was not working..... apparently the computer tells the tv that it will not be able to cool. I cleaned things using air and basically followed the wires for the cooling fan and wiggled them... lol.. works fine now
1helpful
Clicking
thats the power supply trying to fire up but there is a fault.
RCA MM61110 Television
I had the same problem sometimes when my Gold Plus would reset itself and include all the channels but only those Over-The-Air channels. The only way I could change the programming was to completely shut down the power. Not just turning the tv off but completely unplugging it from the wall outlet. When you turn your tv back on you'll be able to choose from Antenna/Cable option. As for Guide,if you don't want to use it, don't set it up, it won't effect anything else on the television.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
