I deleted roxio manager from my pc and this window keeps flashing up (annoying so) with windows installer. Cant stop it
Try this
Click on Start.
Select Run.
In the "Open:" field, type: cmd.
Click OK.
An MS-DOS Prompt window will come up on the screen with a blinking cursor at the command line. In this window you will need to do the following:
Type msiexec /unregister and press Enter.
Type msiexec /regserver and press Enter.
Re-boot your PC and check
SOURCE: Roxio Media Manager continues to try to install
After reading your problem I came across some interesting references about roxio and agent.exe.
Seems agent.exe is used by many programs to update themselves over the internet, and it was giving a lot of people headaches by using 70% or more of their CPU, like yourself.
So, I wanted to send you a few quick thoughts on how to hopefully fix your situation.
First, there were complaints about stuff trying to install itself on and on, and it was because there were command lines in the STARTUP MENU calling upon them to install every time windows starts.
So to try to fix this if its happening in your case........
Go to start>run>and type in msconfig and click ok.
Now click startup and uncheck these items.
issch
ISUSPM
'ISUSPM Start Up'
'ISUSSCheduler'
Adobe Reader Speed Launcher
Quick Time Task
Igfxtray
HotKeysCmds
MSMSGS
WMPNFCSG
COMMUNICATOR
PERSISTENCE (igfxpers)
DLA
Then click apply, then ok and restart your computer. When windows starts, you will see a window saying that changes were made to the configuration utility. When you see it, click on the little white box saying not to show this any more.
And if you really miss not having something you unchecked, you can always go back there and recheck it!
Maybe now you will have the chance to purge all things Roxio from your system.
Best of luck!!
