Question about Toshiba Satellite A135-S7403, A135-S7404, A135-S...
How do I get my Toshiba Satellite Laptop to recognize an external mic? I plugged one into the audio input port, but the computer doesn't recognize anything coming in and will continue to record wi
    New Friend:
  • 41 Answers
There is a setting in the control panel<sound to choose your default input and output for the sound card
Posted on Aug 20, 2012
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: External monitor issues with Toshiba Advanced Port Replicator III
DebitGuy
I have the exact same problem with a Tecra Laptop and a ViewSonic monitor - Did you manage to resolve this at all?
Thanks in advance
Stu
Posted on Jun 29, 2009
Anonymous
  • 100 Answers
SOURCE: No sound coming through Toshiba Dynadock station
Try to plug in the speaker jack to Headphone jack on you laptop not to your docking station. So the desktop speaker is treated as an external average speaker. GoodLuck!
Posted on Jul 03, 2009
pgeee
SOURCE: no sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Posted on Feb 22, 2011
muntejaya
Muntejaya Ginting
  • 10421 Answers
SOURCE: I am getting no sound from external speakers when
Please get the driver here :
www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav...
Regards, Jay__cvf3
Posted on Mar 02, 2011
Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
Mar 21, 2014 | Computers & Internet
How do I connect an external microphone to my Toshiba Salellite Laptop computer?
Right click over speaker icon (next to your clock right bottom corner), click recording devices. Clic on your external mic, clic on properties, at bottom on the new window select "use this device (enable)"
Aug 20, 2012 | Toshiba (P000257700) Microphone
1 usb port on toshiba satellite c660 doesn't recognize mouse
If is just a USB port, then it could be a driver problem, or that USB hub is turn off, or is a fried/bad USB port. Try another USB device on that port too.
Mar 19, 2012 | Gigabyte GA-8I845GVM-RZ Motherboard
I can`t use an external monitor connected by VGA port for my Toshiba Satellite M55 S331. I need to know if the port is damaged?
The M55 series does not output to external VGA automatically. You can either go into Setup (press F2 when computer is starting) or use FN F5 in Windows to toggle between LCD, monitor, or simultaneous output.
The monitor port should be standard, so as long as the plug on your monitor doesn't have any bent pins, it should work.
Jul 26, 2011 | Toshiba Satellite M55-S331 Notebook
I have a Macbook Air with Microsoft Word Home and Student 2008 installed on it. I use the audio recording feature on in Word to take notes in lectures, but since the internal mic was not enough to capture...
In sound system preferences when the external mic is plugged in, there is a drop down menu in the input tab that says "Use the audio port for:" make sure it says input.
Mar 22, 2011 | Apple MacBook Air
My Toshiba Satellite 2805 S301 USB 1 port, does not recognize my Passport external Hard disk drive. What can I do to solve this problem ? Thank you, very much for your assistance.
Hi
assuming that the external hard disk is usb
i would try this
plug in the external hard drive
then go to device manager
then hover your mouse at the top of the box
and look for a icon that says scan for new hardware
then hit the scan icon
your laptop may or maynot recognize the external hard drive at this stage
now leaving it plugged in restart the laptop
and with any luck windows will now recognize it
good luck
hope you get sorted with it
Mar 20, 2011 | Toshiba Satellite 2805-S301 Notebook
I Accidentally Disabled the Built-in Microphone on my Toshiba Laptop and I Can't Get It To Work Again?
There is a built-in microphone located beside the built-in web cam. however, if the microphone should stop function, or you want to use an external mic, there is a mic input jack beside the eSata/USB port.
Jan 24, 2011 | Toshiba Satellite L500 Series Notebook
I have Toashiba laptop Satellite A135-S2276. The laptop doesn?t recognize my USB flash drive. Apparently the device was detected by Windows because as soon as I plugged it in, a balloon pooped up and it...
Check it on another computer. if it still doesnt work then your backup is gone. if it does work maybe you should take it in. also try other accessories in that same port. if other stuff doesnt work then you'll probably need to fix the port. also check the drive on any USB ports in the back of you pc.
Regards
Jul 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Tv tuner support
Put it into the microphone port. It will adjust to the line level.
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A135-S7403, A135-S7404, A135-S... Logo
304 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
