It needs to be repaired. Its leaking water from underneath and now it trips the power in the kitchen whenever I plug it in...
SOURCE: Z5 back is not latching-- needs to be removed-- but how?
You first need to remove the Jura crest by turning it clock wise. I use a piece of ruber pressed against it to help.
Then you will need a special screwdriver for the oval shaped screw heads.
I ordered the screwdriver from germany; www.juraprofi.de.
The cover can then easily be removed by sliding upward.
SOURCE: I have a Jura-Capressa S9
I have fixed this problem..................there is a small attachment on the back (2 in fact). the inlet & out let of the boiler.
The start to leak for some silly reason. U need to replace this
SOURCE: jura capresso z5 not working
Call Nick or Anthony at Style Cafe on 0844 2279229 they have a wealth of knowledge on these machines and can Service them if required
SOURCE: My Jura Capresso, Z5 is
Hi The connectors on capresso machines are very tricky. The reason for the leaking could be to do with the seals. Take it apart and make sure all the rings and pressing clamps are in the right place. Also take a good look and on your hot water tank, and the pressure relief valve in back of machine. Also it is recommended that the Jura coffee machines to be serviced every 2 years. Thank you for contacting fixya.com
Please get back to us if you have further query else please accept the suggestion.
