Question about Lenovo G530, G550, G560 (A1965SM3100416176)
Laptop screen flickers
Screen flickers and jumps
Posted by jamiet73 on
michael ramos
    New Friend:
  • 86 Answers
Try to plug the laptop to a external monitor. I the display doesn't flicks your Motherboard or the graphics card fine and you need to replace your screen LCD
Posted on Aug 21, 2012
I have an HP/Compaq nc6220 laptop. When I try to boot it up it flickers the goes to black screen and won't boot up. What should I do?
If you havent tried to boot your operating system from a disk or jump drive (which you can get from you local PC store for around 5 bucks) then I'd say your either missing harware components, or the ones you have are fried, and your better off buying a new PC.
Sep 25, 2012 | HP Compaq nc6220 Notebook
My computer screen keeps jumping or won't stay up
Your laptop screen refresh rate is low (Hertz). When your screen refresh rate is slow, it will flicker and stutter.
To fix this, right-click your desktop, and go to Personalize.
When you're there, go to "Display Settings" and go to "Advanced Settings", on the "Monitor" tab you'll see the screen refresh rate. Change it to the highest number you see.( min 65-70)
Although the change will shorten your laptop battery life, it will fix the problem. Just keep your charger on until it's fully charged, and it should be good.
Jul 22, 2012 | Computers & Internet
My Acer Aspire 6530 screen has been doing an odd purple-ish flicker as well as jumping around. This usually happens when I'm using the internet (Google Chrome) and the web page jumps around making...
Is this problem on Google Chrome only? try microsoft browser and let me know the result, I would recommend a full scan of your system to rule out a virus. If it turns out Google Chrome is the problem uninstall the program and reboot the machine, now do a fresh install, it may fix the problem.
Apr 22, 2012 | Acer Aspire 6530-5143 Notebook PC
Dell laptop matter on the screen flickers
If it happens after sometime when you turn on your laptop and working on any application, it is the problem of your laptop's screen, you need to repair it.
Dec 17, 2011 | Computers & Internet
I have a fujitsu siemens laptop and the screen keeps flickering and jumping, can u help please
The first thing you need to do is check the screen connection to the motherboard.
Without knowing the model of the laptop I can’t really advise you on how to do this, however it’s normally under the power on button strip.
If the connector is tight and in place it will most likely be the screen inverter which is under the fascia of the screen.
Whiteout knowing the model it’s difficult to offer advice.
Feb 15, 2010 | Computers & Internet
My Hp pavillion dv4 notebook pc's screen is flickering quite badly. It happens every few seconds and everything seems to jump up and down once and go back to normal. Tapping or hitting screen or any part...
Flickering is a back light issue, jumping around would be caused by the screens reaction to a bad inverter and so would the backlight as well. So flickering backlight and jumping would be a inverter issue causing both problems so I would replace them both.
Thanks if you like my adivice please rate it with the thumbs and leave feedback!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 19, 2009 | HP Pavilion dv4000 Notebook
Screen jumping on acer aspire 5920
First boot in safe mode and the display resolution will be minimal if the screen appears ok with big fonts then try and adjust the normal resolution but not high resolution like 640x480 with 256 colors, if it works then you acer laptop screeen is fine but the exactly display drivers to be reloaded else there is a problem with your laptop screen which needs to be replaced
Mar 18, 2009 | Acer Aspire 5920 AS5920 Notebook
Screen flicker/jumping
first check loseconection and tube light and nearaset spk for sparking .and check the earth of monitor main waire
Nov 18, 2007 | ViewSonic GA771 Monitor
Lenovo G530, G550, G560 (A1965SM3100416176) Logo
276 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Steve Sweetleaf
Steve Sweetleaf
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
