There are 3 fuses on the main board and number 1 fuse is dead. do I have to replace the whole board or can i bypass the fuse
If fuse is dead, there must be some reason for that. Some short circuit or so. Without rectifying the fault, if you replace it with an other fuse, the fuse you insert will also blow out, and might make more faults to occur. The rating of fuse will be marked on the printed circuit board itself, very near to the fuse.
SOURCE: Vizio GV47L, How to replace fuses on motherboard?
Fixed my 47" GV47L for $7.18... Did the F3 Fuse bypass solution, and it worked like a champ!!! No problems since! The part that took the longest was the drive to Radio Shack!!!
SOURCE: My Vizio gv47l went black. I checked the power
Since this is an LCD TV, it's probably a backlight or backlight inverter issue if the problem occurs on all sources and the onscreen menus. If the audio can be heard, this is even more likely to be the cause. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx. Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
do test fuses with TV set on or off?
