Question about Danby DWC283BLS Wine Cooler
Danby DWC166BLSRH is not cooling. Fan is on and a clicking sound comes on, and compressor is very hot but will not cool.
Posted by salz on
Britt Walker
    New Friend:
  • 16 Answers
I have the same problem. Mine probably needs refrigerant so it's a safe bet that yours does too. I'm going to order some and fix it, then update.
Posted on Sep 22, 2014
5 Related Answers
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: My Danby DWC512BL has stopped cooling. The
moz-screenshot-22.pngmoz-screenshot-26.pngReplace that fan
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 06, 2009
macgivor
  • 234 Answers
SOURCE: Danby DWC513BLS does not cool. Fan is on, but
Before you worry about where to get parts,you need to know what is wrong and what parts you will need. When a compressor does not run but the fan motor does, then either the compessor is bad (in which case you need refrigeration expertise) or the starter components have failed ( in which case you can replace. The two most common failed parts are the start relay or the overload (both attached to the compressor. Goodluck, Macgivor
Posted on Jan 31, 2010
Anonymous
  • 31 Answers
SOURCE: Our danby dwc 283bls is not cooling. The motor
The motor will run pretty hot. How old is the unit? It probley just needs to be cleaned out. Most problems with cooling is just clogged up coils. Is the motor just hot or is it vibrating to?
Posted on May 22, 2010
Anonymous
  • 26 Answers
SOURCE: DANBY 512BL not cooling
its because the weather
Posted on Jun 12, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my danby beverage centre does not cool anymore 3
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ,.,
Posted on Oct 08, 2010
Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Nov 27, 2012 | Danby Refrigerators
Danby Kegerator runs but does not Cool
sounds like maybe no coolant in system if compressor is working. you know like in your car a/c unit, sometimes refrigerant needs to be added. just a guess, I'm not an expert.
Nov 08, 2012 | Danby DKC645BLS Compact Beverage Cooler
Fridge and freezer not cooling. Hot air coming from front of fridge.( Overly Hot and has a smell of burning )
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
please rate my answer.
Feb 21, 2011 | Amana Refrigerators
My danby beverage centre does not cool anymore 3 years old. compressor is hot. fan sounds and appears to work well all coils are clean.
heatman101 ,.,
Oct 06, 2010 | Danby DBC514BLS Silhouette Beverage Centre
If compressor is running and it gets hot and the unit does not cool the compressor is bad or you have a leak in the system. if you see oil there's a leak.
May 22, 2010 | Danby DWC283BLS Wine Cooler
Top evaporator fan not working and compressor hot , not cooling below 79 degrees
the top fan is not suppose to run all thetime only when its too cold and the heater kicks then the top fan will come on,you probley have a leak in the system
Nov 10, 2009 | Danby DWC283BLS Wine Cooler
Compressor runs and gets hot but does not cool unit
This product has been discontinued
i dont think many danby units are parts supported
more likely generic after market parts fitted by air con mechanics do the job
relay first might be a thematic one and an compressor motor fan relay
then check gas pressure
https://www.winecoolerdirect.com/danby-wine-cooler-dual-zone-dwc283bls/DWC283BLS.html
Service Manual.pdfwww.reliablepartsinc.com/danby/Manuals%20.../Service%20Manuals/DWC282%20%...
Mar 06, 2017 | Danby DWC283BLS Wine Cooler
Danby DPAC8020 loosing it's cool
Had the same problem 5 YR OLD unit and I was sweating. Took off back and side panels. Cleaned out the H2O hose and Took out lots of dirt and grim covering the unit. It seems when the unit is covered with this dirt n grime the auto cut off engages to prevent damage and/or possible fire. After a through cleaning I grabbed for the blanket that evening. Been on 12 hours now and gosh the room is cool,
Aug 24, 2008 | Danby DPAC8020 Air Conditioner
Danby DWC283BLS Wine Cooler Logo
981 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
