SOURCE: Display control unit frozen, display just reads standby
The reason is because the housingin is a little bit broken or throw the keypad water came inside yuor Display and after this the oxidation ha destroyed a part of the printid circuit or the switch of the keypad
SOURCE: My Raymarine ST6001+ says no signal.
if the ST 6001 shows "no data" and alarms, the course computer is most likely bad. Control head failure is very uncommon, hower you should look at the brain box (T400) and move the control head to the other seatalk terminal (there are two) you may have just one failed SeaTalk port and can use it as is, otherwise, Raymarine will still fix (this week) 847-746-0100
SOURCE: Clutch failure of Raymarine M81130 linear drive
Try putting 12 vdc directly to the clutch circuit. You should hear the clutch engage. If this is operating properly, then the course computer circuit has failed. If this is not working then the linear drive needs to be rebuilt.
