Question about Porter Cable Variable Speed All-Purpose Tiger Saw Kit With Quick-Change Blade Clamp And Case 9737P
Blade broken off in quick change tiger saw chuck
Pc85trso orbital reciprocating saw, blade broke off inside chuck
Posted by lwbradsha473 on
mike butler
    Brigadier General:
  • 6,468 Answers
Use a pair of tweezer to pull it out or a magnit
Posted on Aug 22, 2012
5 Related Answers
J. Bradshaw
  • 121 Answers
SOURCE: how to remove the blade on a tiger saw
At the base of the blade where it attaches in the saw you will see a round in shape with ridges fixture. Turn it so the slot is in line with the blade. Then you will be able to remove the blade. If the fixture does not turn, move the blade up and down while you turn the fixture.
Posted on Jun 19, 2009
Mike258
Justin Case
  • 1498 Answers
SOURCE: How do I replace the blade?
Hi rq,
Look at the base of the blade, there is either a half twist quick disconnect or an allen screw.
Safety first: Unplug the saw.
If its the allen screw it will be located to one side of the blade. Just loosen it , pull the blade out.
The half twist ring doesa what its name implies. Twist it as far as you can (holding the saw with the bladed to the ground allows it to drop out) to free the blade.
Best reqards
Mike
Posted on Sep 11, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Posted on Sep 14, 2009
Anonymous
  • 59 Answers
SOURCE: I have a Porter cable Tiger Claw saw model 9750.
detent latch broken
Posted on Nov 22, 2009
Anonymous
  • 5 Answers
SOURCE: Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Posted on Dec 08, 2009
The chuck for my reciprocating saw seized up due to rust. It is the turn style chuck. How can I in seize it?
use some penetrating fluid and gently work it back and forth until it frees up, the replacement parts cost around 20.00 if you need them. Let me know if you need more assistance
Sep 12, 2011 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
I bought a Dewalt DW310 reciprocating saw and there seems to be no way to install a blade. The instructions show a wheel to turn to unlock the blade chuck but the wheel is up inside the saw body where you...
The blade clamp collar is a spring loaded knob of sorts that holds the blade in place. If you are not able to pull the blade shaft out of the saw to get at it, plug the saw in and hit the on/off trigger a few times to get the shaft and knob out of the body of the saw. Once you can get at the knob it should be easy to turn it and insert a new blade. Let me know if you have problems.
Aug 30, 2010 | Dewalt DW310K Heavy Duty Reciprocating Saw...
I have a Bosch RS20 recip saw. A blade broke off in the chuck and I can't get it out. What should I do to get it out of there? Thanks for your help. Dan
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Aug 17, 2010 | Bosch RS20 13 Amp Reciprocating Saw
Reciprocating saw problems cannot get broken blade out of chuck
heatman101
Aug 15, 2010 | Dewalt Saws
Pin and lock where the blade is come off and giving me a hard time putting it back
heatman101
Aug 15, 2010 | Skil 9.5 Amp Orbital Reciprocating Saw...
How do i change the blade in a reciprocating saw?
heatman101
Aug 05, 2010 | Skil FactoryReconditioned 920501RT 85 amp...
Blade stuck in keyless chuck on sawzall. pin or spring must be broken. Any suggestions on how to get the blade out
heatman101
Jul 14, 2010 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Blade stuck in the chuck
If you have the lock released and can't get it out try pointing it towards the ground and running it. the piece should fall out unles it is still locked in
Nov 27, 2008 | Bosch RS20 13 Amp Reciprocating Saw
Porter Cable Variable Speed All-Purpose Tiger Saw Kit With Quick-Change Blade Clamp And Case 9737P Logo
1,071 people viewed this question
Top Porter Cable Garden Experts
JOHN LAPIER
ray gallant
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
