Activision SpiderMan Web of Shadows Logo
ZAMIN M.H RAZVI Posted on Aug 19, 2012
When i try to open spiderman web of shadows it comes but after some time it says THIS PROGRAME IS NOT WORKING I CHECK FOR PROBLEM I SAYES APPCRASH
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 03, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
361
Points
Download swiftshader 3.0 then paste one of the files beside the game exe and play the game
my problem is apphangb1
When i am starting this game it will not open, so i open task manager & that will show as not responding & the problem is AppHangB1. What is the solution for this?
The issue is typically due to too many windows processes being open at the same time. Make sure you close all open windows and file folders before launching the game. Also installing all the latest windows updates may help. AppHangB1 is windows trying to unfreeze itself. So if all applications are closed the game should run no problem.
Password thq
there is no choice you've got only one chance to use password recovery i know it takes a long time but be patient i havent even figured out the password yet
4helpful
APPCRASH error please help
When program files or files within your computer's registry have become corrupted, this can cause the programs to unexpectedly crash. When a program crashes, you will likely get an Appcrash error. The error message will say "Windows Media Player (or whichever program has crashed) has stopped working" and then list rows of technical information regarding the cause of the crash. Unless you are a computer programmer, you may never fully understand what caused your program crash, but that doesn't mean that you can't fix it.
Delete any new programs that you have downloaded. Often, the cause of corruption in a computer system are bad downloads that bring harmful files onto your computer. If you started to get the Appcrash error on your system after downloading a new program or software from the Internet, it's highly likely you have downloaded a bad product. Use the "Add/Remove Programs" feature in your "Control Panel" to get rid of the program immediately.
Uninstall the program that is crashing. It is possible to fix the program's corrupted files while the program is still installed, but to make sure that you clear the program files completely, it is safest to completely uninstall it from the system.
Run a full scan of your computer. Your computer should already have antivirus software installed that can scan for corrupted files and either fix them or delete them from your system. If you do not have antivirus software on your computer, that could be a big part of the problem. Purchase and install antivirus software as soon as possible. These are designed tor from outside threats. Once you have the antivirus program installed, open it and click "Scan Computer." The antivirus scan will isolate bad files and you will be given the option to remove them from your system.
  1. Reinstall the program that was crashing. Now that the corrupted files have all been removed, your program should run smoothly after reinstallation.
  2. Check for program incompatibility. If, after a thorough scan and cleaning of your computer and reinstallation of your program, the Appcrash errors continue, the program you are trying to use may not be compatible with your program. For instance, there are some DVD softwares, such as Media Now, that do not work correctly with Windows Vista. These lists can be easily found online. If this is the case, you will have to purchase a software program that is compatible with your OS
You should download a program such as RegCure and run it from time to time. If you are unable to download a copy let me know and I will give you a link on my web where you can download it.
1helpful
Yeah i just go this game spidey web of shadows and this is the 2nd time its happened its the second time gone to gamestop to get a new on which is actually a preowned one and it stops at the begining...
Well your disc is officially garbage because it's scratched for sure. Don't bother trying to fix your game disc. Do what I did. Go to sellitbroken.com and sell your game to them. They will give you good money for it.
1helpful
2answers
1helpful
3answers
Top Activision Video Game Consoles & Games Experts
Sean Wright
Sean Wright
MegaByteMe
MegaByteMe
john h
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
