Question about Philips DVDR3330H DVD Player/HDD Recorder
How to enter disc menu for finalizing dvd-r on philips dvdr3330H
I burn dvd on player but it wont play in any other device. I cant find any button on remote control saying disc menu or anything of that nature, even in main menu, I think I tried everything, any gusses? thanks
Posted by pucvolka on
  • Philips Master
  • 6,301 Answers
The Disc Settings menu is accessed from the Disc Index Picture screen (so it's not as easily accessed as on other brands of DVD recorders). When you first put a recorded disc in the device, you'll see this index screen. At this point you need to press the UP arrow on the remote repeatedly until the disc content menu appears. This is a screen with the disc name, amount of recording time used and the date of the first recording. Then press the Right arrow button to get to the Disc Settings menu. Use the Down Arrow to reach the line that reads Finalise Disc. Then press OK and then press OK a second time to confirm the action.
The documentation for the DVDR3330H is available from Philips here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=hu&ctn=DVDR3330H/02 . See page 52 for the screen captures. The Finalise steps are on page 53.
I hope this helps.
Posted on Aug 19, 2012
5 Related Answers
Anonymous
SOURCE: philips dvp 3020 dvd player will not play, the "no disc" sighn keeps coming on.
Try this. Wait for the "no disc" sign to appear, and only after that load the dvd. The 3020 I have works alright when I use this method.
Posted on Aug 20, 2008
Anonymous
SOURCE: My dvd model is philips dvp 3005 and it is in standby mode
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
Anonymous
  • 192 Answers
SOURCE: philips 622 dvd player
Its time to clean the reader, thats a little laser eye in side the unit. that gets dusty, buy a cleaned disk, follow instructions, I bet ya this helps. DFD
Posted on Apr 11, 2009
mrfixie
  • 303 Answers
SOURCE: have lost car adaptor & rechargeable battery pack for PET704
You can buy a new one by clicking on the hyperlink:
buy replacement DC CAR power Adapter for PHILIPS PET704 PORTABLE DVD PLAYER
Posted on Sep 06, 2009
Anonymous
SOURCE: cant finalize dvd on a magnavox zc320mw8
you have to push stop from the title menu, then push setup. Then go to disc edit and finalize is there
Posted on Nov 24, 2009
2helpful
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
My recorder DVDR 3330H has the "finalize" in the menu disk but I cannot click on it .
Probably you don't have a DVD+/-R disc inserted but a DVD+/-RW. A rewritable disc can't be finalised and doesn't have to be.
22helpful
2answers
Can't figure out how to finalize, I record fine but can't find anything to finalize it, I have no manual, thanks for any help. Magnavox MWR20V6 Jim
Insert the dvd you want to finalize. When the menu loads press Stop and then press Setup on your remote control. Scroll down to disc edit and press the Enter or OK button. You should see the word Finalize there, select it and then it will ask to Finalize Yes or No. Select Yes and it should finalize your disc perfectly and play on any player.
1helpful
Dvdr3576h will record on dvd+r but will not play on other devices
You will need to finalize the discs on the Philips. I know the manual says that +r may auto-finalize, but I found that finalization sometimes fails on the first attempt. Go into the menu for the Philips, and select the Edit Disc -> Finalize option. Once finalized, your disc should play in other players.
-Tha Mp3 Doctor
3helpful
Recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
DVD will not finalize
I have a Zenith XBR413 that I have a problem with when I copy from VCR tapes to DVD-R discs. After I copy them, I can finalize the disc using the SETUP button on the remote and then choosing the very bottom disc icon at the bottom of the menu screen. It then leads you through the finalization procedure. But the disc will still not play on any DVD player but the XBR413
7helpful
3answers
The magnavox zc320mw8 will not finalize a dvd for playback on anther dvd player
Try this. Insert DVD. Press SETUP button. Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
Philips DVDR3450H
Put the DVD back into the drive...Then open the DVD menu by selecting the first tittle on the disc....Hold down the up arrow on the remote to make the "Editing menu" appear....Then select "Finalize Disc".
These instructions can be found on page 54 of the instruction book.
2answers
Playing recrded DVD's on other devices
are the dvd devices you are trying to use able to play copies or not as alot of dvd players are restricted and wont play copies let me know if you need further assistance
2answers
Playing recorded dvd on other devices
you have to finalize disc before try it in other players.
Open Questions:
See all Philips DVDR3330H DVD Player/HDD Recorder Questions
Philips DVDR3330H DVD Player/HDD Recorder Logo
Top Philips Televison & Video Experts
 Francisco Mauricio...
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
