The dvd player would not work by not ejecting the cd. The product is DVP-DR510H and will also turn the volume all the way down to minimum by itself. The dvd player buttons will not work on the actually dvd player except on the remote and the power button on dvd player.
I think that the reader and the lense are worn-out, which means that you should change a new one. But if you want to find out what causes make the issue, you can check this article to find out the answer. Article is in the link below. Hope it helps.
Guide: Why Does My DVD player not work on My Computer
The controller board is slowly dying. I think it might be time to buy a new DVD player.
SOURCE: SONY DVD RW AW-Q170A not working....
one reason may be that your writer may be old and the lense must have died.
another is that the lense require cleaning.
the last one is that you need to upgrade the drivers and firmware for your sony writer which you will get here.
http://sony.storagesupport.com/models/21
If all the above things dont work, replace it.
SOURCE: cd drive not eject
if it is not hardware problem then follow these steps :-
First delete dvd device from the Device
manager.
just type DEVMGMT.MSC in run command.
then delete DVD
Device
after that restart the system.
if not solve then
follow next step ;-
If the drives are still listed in the
Device Manager, delete them then carefully follow this
fix:
"Upper/Lower Filters:
a. Click on Start -->
Run --> and type in 'regedit' followed by the enter key
b.
Expand the "HKEY_LOCAL_MACHINE" key (looks like a folder)
by double clicking it (or clicking the "+" next to it.)
c.
Expand the "SYSTEM" Key
d. Expand the
"CurrentControlSet" Key
e. Expand the "Control"
Key
f. Expand the "Class" Key
g. Look for a key
containing the following string of letter and
numbers:
{4D36E965-E325-11CE-BFC1-08002BE10318}
h. Highlight
this key by left clicking once on it
i. On the right hand side you
are looking for "UpperFilters" and "LowerFilters"
under the "Name" column, once you find these delete them by
right clicking on them and choosing "delete"
j. Exit the
registry by clicking on the "X" in the top right hand
corner of the screen
restart the system.
SOURCE: my dvd drive is not ejecting while i click the
i think ur drive is old, use the emergency eject (by inserting a pin to the hole just below the tray) and always keep a disc inside the drive else remove the drive and remove the cover, replace the mechanism belt, hope it works.
SOURCE: Cannot write onto CD or DVD
I've never heard so much rubbish in my life,version 7 of Nero works with XP and so does version 6 ,I still use 6 on my PC as it's so easy to use
SOURCE: Unlock region code on SONY VAIO VGN-FZ11S
hi there might be...first go to my computer, then locate the dvd drive, right click that and then properties, then click the hardware tab at top then in the list locate dvd drive then at bottom right click on properties then click dvd region and then you should be able to change it....hope that helped
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
